Old 01-15-2013, 11:10 AM   #1
Iggy's Avatar
Water Filter Part Number
Has anyone found and replaced their water filter element?
I was just wondering what catagory of number it is.
Mine seens to be a mesh type that I have cleaned in the past and reinstalled. Is this what you have?
Old 01-15-2013, 11:19 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
WaterPur Filters
This is what the original cartridge in my coach was. I've seen them cheaper on line. You can get similar cartridges at HD or Lowes.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-15-2013, 11:34 AM   #3
Iggy's Avatar
Found this information
CCI-10-Ca (CCI-10-C)
Supplied as original equipment in approximately 40 different brands of RVs
CCI-10-CA is a WQA Gold Seal Certified Product
Rated for 10,000 gallons of chlorine reduction for one year
Initial pressure drop of only 2.6 psi where others have pressure drops of 10 psi or more
Beware Of Imitations!
The WaterPur™ CCI-10Ca Cartridge is supplied as original equipment in approximately 40 different brands of RV’s. (Several different websites are infringing on the WaterPur™ name to lure you to their site, then they offer inferior “substitute” or “replacement” cartridges, claiming that the real WaterPur™ cartridge is not available. This is simply not true — they are still available through Authorized Retailers!!
The Genuine WaterPur™ CCI-10-Ca is a WQA Gold Seal certified product. It is manufactured with premium high performance coconut shell carbon and advanced binder technology utilizing a precision compression molding manufacturing process and a polypropylene dirt capturing wrap. (Many “imitators” are manufactured with inexpensive activated carbon powder on cellulose [paper]). With this extreme attention to detail, the WaterPur™ CCI-10-Ca delivers consistent pressure drop and contaminant reduction, cartridge after cartridge over an extended period of time.
The Genuine WaterPur™ CCI-10-Ca is rated for 10,000 gallons of Chlorine reduction or one year. There are many of the cheap “imitators” rated at 300 gallons or less and need to be replaced in as little as a weekend to 30 days. The Genuine WaterPur™ CCI-10-Ca is rated at 2.5 gallons per minute where most “imitators” are designed for ¼ to 1 gallon per minute. (You would have to run around in the shower to get wet at that rate!!) Some imitators flow water at higher rates than their rated flow, meaning you get water, but it is not adequately filtered.
The Genuine WaterPur™ CCI-10-Ca has an initial pressure drop of only 2.6 psi where others have pressure drops of 10 psi or more!! (Try using that with an RV’s 12 volt water pump!!)
The Genuine WaterPur™ CCI-10-Ca has a high affinity for certain Volatile Organic Compounds (VOC’s). VOC’s are organic compounds that can be isolated from the water phase of a sample by purging the water sample with an inert gas, such as helium, and, subsequently, analyzed by gas chromatography. Many VOC’s are human-made chemicals that are used and produced in the manufacture of paints, adhesives, petroleum products, pharmaceuticals, and refrigerants. They are often components of fuels, solvents, hydraulic fluids, paint thinners, and dry-cleaning agents. VOC contamination of drinking water supplies is a human health concern because many are toxic and are known or suspected human carcinogens. VOC’s include: Benzene, Tert-Butyl chromate, Dichloropropane, Formaldehyde, Methylmercury, and a host of others.
Genuine WaterPur™ CCI-10-C series cartridges have been utilized in approximately 40 of the finest RV brands in the USA for the past ten years. Ask yourself this question: “WHY IS AN RV MANUFACTURER PRODUCING 50,000 RV’S PER YEAR WILLING TO SPEND $500,000 PER YEAR MORE TO USE THE GENUINE WaterPur™ CCI-10-Ca INSTEAD OF THE “IMITATORS?” The answer is simple. To produce the finest RV’s available, you need to use the finest technology, the finest design, and the finest components.
Do you see anyone trying to imitate or lure you away from the other brands? You deserve the best. Demand a Genuine WaterPur™ CCI-10-Ca for your family and for your peace of mind
Old 01-15-2013, 11:39 AM   #4
Iggy's Avatar
The CCI-10-CA replacement filter is a WQA Gold Seal Certified Product that is rated for 10,000 gallons of chlorine reduction for one year of use. The initial pressure drop with this filter in operation measures only 2.6 psi, where others have pressure drops of 10 psi or more. This filter is supplied as original equipment in approximately 40 different brands of RVs.
Specifications:
High Performance Coconut Shell Carbon
Thick Wall For Long Life, Greater Chlorine Taste And Odor Reduction
Solid Compression Molded Carbon Block For Long Life
Highly Effective Chlorine Reduction Through 10,000 Gallons At 2.5 GPM Flow Rate
Reduces Sand, Fine Sediment And Rust Particles
Reduces Certain Volatile Organic Compounds (VOCs)
Temperature Range: 40-165 Degrees Farenheit
Do Not Allow This Unit To Freeze
Recommend Replacement Of Filter Cartridge Every 12 Months Replacement Cartridge For Model Number CCI-10-CLW And CCI-10-CLW12 Filter Housing Canister
Fits Standard 10-inch Filter Housings
For 2 1/2-inch to 2 7/8-inch OD Cartridges
Old 01-15-2013, 12:30 PM   #5
Berkshire 390QS
NO3putt's Avatar
Get ours at Lowes. These are expensive from the company.
Old 01-15-2013, 12:42 PM   #6
copsuno's Avatar
Around $30.00 at RV stores, Camping world and any Camper sales.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 01-15-2013, 01:10 PM   #7
tom50mg's Avatar
I have found these water filters at Princess Auto Stores in Canada for $9.00,there is 3 different micron size,s that they stock as well.
tom50mg is offline   Reply With Quote
