Water heater access
The bypass valve in the water heater compartment on my 2011 337DS is leaking and needs to be replaced. The only access I can find is the hand hole in the bottom of the casing----which is OK to operate the valves but not big enough to work on the pipes.
My thoughts are to remove the casing on the w/h cover (4 screws) and then remove the surrounding side panel on the coach.
Is this the way to go, has anyone had the side panel off and how is it held on to the coach frame???
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
