Old 06-18-2014, 08:22 PM   #1
Water heater bypass
Does anyone know if the Georgetown 377 has a bypass valve on the water heater and how to access? I am learning how to winterized this rig? Also, any tips on winterizing the ice maker? I found a bypass near the water basement, not sure what it is for.
SaladoBob is offline   Reply With Quote
Old 06-19-2014, 05:08 AM   #2
fonzie's Avatar
Locate your water heater access panel outside coach, then look underneath coach for a access plug. Remove and reach inside for all the water heater valves.
Name:	water heater access plug.jpg
Fonzie
Old 06-20-2014, 08:58 AM   #3
I can understand you wanting to get a handle on things, but geez, summer is just starting and you're talking about "winterizing", yikes! LOL!
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 06-20-2014, 09:01 AM   #4
forgot to mention, look under your rig where the water heater is and you should see the access port to the by pass. You'll need a flash light to look up, there should be 3 valves to turn.
sherman12
Old 06-20-2014, 06:04 PM   #5
Cornelius's Avatar
Same round access cover, but on my Georgetown it is located on the side of the water heater compartment, facing the rear tire.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 06-28-2014, 11:47 AM   #6
Thanks Fonzie. Been without Internet for a few days but really appreciate the help.
Old 06-28-2014, 11:49 AM   #7
Headed overseas for 2 years and putting the rig in storage. Crazy, I know.
Old 06-28-2014, 12:30 PM   #8
Ford Idaho's Avatar
Are you going to just blow it out with air or add antifreeze as well?
I ask because two years is a long time for the AF to sit in your pipes and what not.
bypass, heater, water, water heater
