Old 08-19-2016, 08:50 PM   #1
Sbryant's Avatar
Water Heater Fuse ?
Where's Elec Water Heater fuse please - '14 GT 360 XL
Sbryant is offline   Reply With Quote
Old 08-19-2016, 09:07 PM   #2
wmtire's Avatar
An electric water heater (or the electric heating element part) should run off of 120 volt AC. This means it has a circuit breaker, not a fuse.
Do you know where your electrical distribution panel is in your RV?
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
Old 08-20-2016, 08:16 AM   #3
Tim & Lisa Trempert
What is not working? There is a switch on the water heater, the breaker and then the element itself which will burn out almost immediately if turned on without water.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-20-2016, 08:30 AM   #4
SeaDog's Avatar
X2 what others have said I would add let us know what you find and what the problem was.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-21-2016, 07:37 AM   #5
Tim & Lisa Trempert
If it's the 12v fuse then it's in the same box as the breaker. However, if it's the gas portion not working it's much more likely to be your board than your breaker.
Tim & Lisa
2011 Georgetown 350
fuse, heater, water, water heater
