Old 04-01-2015, 12:08 PM   #31
Mr. Dan's Avatar
Originally Posted by OldCoot View Post
And what is an "ingnighter"?
I think I can guess. I 'borrowed' it from a post above!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 04-18-2015, 01:46 PM   #32
handbuilder's Avatar
Big oil - what was the verdict? Did your water heater work ok or no? Curious - because same thing happened to me last weekend on my first trip since dewinterizing. I haven't pulled it out of our shop to check it out yet...hoping you have good news to share? Spouse is optimistic bur after reading things posted on this topic, I am thinking I should jist order that element and keep on stand by.
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 04-18-2015, 01:57 PM   #33
Krazymace's Avatar
Originally Posted by sherman12 View Post
That may be true about the "crappy little switch", however what would it have taken for GT to wire it to the panel or somewhere convenient during the build process.
Learned the hard way that is you forget to turn the switch to off and then drain your WH, the element won't last long.
Krazymace is offline   Reply With Quote
Old 04-19-2015, 09:45 PM   #34
bigoil7's Avatar
Mine was fine because the black switch outside was off. I just dewinterized a few days ago, filled the water heater and turned checked everything out. I turned on the propane, and then the water heater switch on the inside panel, and I heard the heater start and the heat coming from the exhaust. I'll be honest, I haven't used the electric side of the water heater, but understanding how it works I'm sure everything is ok.
2015 Grey Wolf 27RR
Ford F150 FX4 SUPERCREW 5.0L
2011 Harley Davidson FLHTP
USAF Vet
bigoil7 is offline   Reply With Quote
Old 04-20-2015, 07:48 PM   #35
Thanks Bigoil!
heater, light, water, water heater
