Old 12-22-2009, 03:54 PM   #1
Unhappy Water Heater Problem
This problem just started last week. The water is hot in the hot water heater, but only cold water comes out of the hot water faucets. Please help if you can. This is a 2004 Georgetown XL 359
charles is offline   Reply With Quote
Old 12-22-2009, 04:29 PM   #2
NWJeeper's Avatar
Your water heater bypass valve is bypassing the unit. Need to find it and turn the valve so it will work. It is usually located close to the water heater. Yours is probably mounted in an outside compartment like ours I would guess there should be an access port somewhere so that you can get behind the water heater. It could also be under the kitchen sink as they do in a lot of the trailers. This valve bypasses the water heater for winterizing purposes, if it isn't put back the other way then you get exactly what you are describing.
Ed & Wendy
www.nwjeepn.com
Old 12-22-2009, 04:31 PM   #3
Have you checked the water heater bypass valve?
Filthy Beast is offline   Reply With Quote
Old 12-23-2009, 06:48 AM   #4
KyDan's Avatar
Um..... just a wild guess but maybe your water heater
is in bypass mode??
Old 12-23-2009, 06:58 AM   #5
Head Rambler
I don't know that I can agree with the above posters! I think it's your water heater bypass valve set on bypass!
Gotta go campin!
Old 12-23-2009, 08:23 AM   #6
Are you sure you have water in the heater tank? Are you really sure you have water in the heater tank? As others have said, sounds like by-pass valve is open. Also check inlet valve. Most of the time they both get turned to winterize a unit. Will need both in the correct position for the water heater to work. If there's no water in the tank, may have blown electric heater element also if you tried to heat with electricity. Carefully crack open "pop off valve" and make sure you have water in the tank.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
