As I eluded to in an earlier post, regardless, I would replace this item to prevent unnecessary trip problems. The bad board turned off the propane part of the heater, but I was able to use the independent electrical side (The electrical element is on 100% of the time regardless of the GAs switch position of the CB is on and the switch on the outside by the heater is also on - I discovered this by accident - Dealer never explained anything when I picked up my RV). As I was off grid (I made my RV 100% off grid capable - do a thread search) 27 out of the 30 days, I used my batteries and inverter to make 120Vac for the heater when ever I needed hot water - once a day.
Direct from Amazon reviews re the Suburban Control Board - You decide
Please do not buy this board. Find the compatible board from Dinosaur Electronics and use that. The board that came on my Suburban water when I bought my travel trailer burned up after only 2 weeks. Had it replaced by the dealer with the same Suburban 520814 board, that one blew after 3 days. Next time, I was on the road and not near my dealer and no one around me had a board in stock. So, I ordered this one from Amazon. This one lasted a whopping 15 minutes. I'm pretty sure Suburban released a recall on these boards, but I can't find a link or anything for that. Long story short, don't buy this board, you're wasting your money.
My camper is less than a year old and my water heater stopped lighting. I have the Surburban sw6d propane only heater. The igniter was not sparking. I tried replacing the igniter first but that did not fix it. I then replaced the board and it works again!
Update: the new board failed in about 7 months. In that 7 months, i might have switched on the water heater only 20 times. These boards seem to be defective. It started taking a long time to light the water heater. Then, it started lighting but would shut off the water heater a few minutes later. Sometimes, it would light but i could hear the igniter sparking as if it was still trying to light. Soon after, the igniter would not even spark. I have since replaced it with the Dinosar electronics UIB S board which fixed my issues. We'll see how long this one last.
Installed in our RV Trailer on 12/3/16 on the propane water heater. Used it only 14 non-consecutive days, between 12/3/16-4/14/17 and it is already BURNED OUT! We did not abuse it, we don't leave the water heater on all the time, we only turn on the water heater a few hours per day.
Had to replace our original water heater after the tank cracked from some very rough roads near Chicago. I installed an exact new replacement, and the circuit board on it only lasted two months. Bought this one last September and everything worked fine through a long trip in May - June this year. Then it quit sometime in July. Finally got around to taking it out and if my memory is correct, this is the same failure as the previous one. Just more made in China junk.
Board did not work. I took trailer (with board installed) to local RV service center. They tested board in their tester and said it was good. However, after ruling out all other issues why water would not work, they installed a new board and water heater worked fine.
The Q3 diode burnt up after 2 uses. Found out it's a problem with this board. Ordered a different brand from the RV dealer and haven't had any issues.
This product was unfinished. There should be a 500ohm resistor on the end. Not a good part. Prolly a thousand like this done. It even shows the needed part in the picture is missing! Right where the connector is!
