Old 03-23-2015, 12:40 PM   #1
Sbryant's Avatar
Water Heater Sag Repair
Brand new, my GT360 water heater painted panel swung out at the bottom due to the weight of the water in while going going down the highway the first day. I could shove it back in place, but it wouldn't stay. I cut a piece if thin tin, screwed along the full bottom length of the painted panel, and, with the painted panel shoved into the proper alignment, screwed the other edge to a parallel brace (all this is under the camper). If no pics show up here, I'll post another.
Sbryant is offline   Reply With Quote
Old 03-23-2015, 12:44 PM   #2
Sbryant's Avatar
Here are the pics
Name:   ImageUploadedByForest River Forums1427132644.519404.jpg
Name:   ImageUploadedByForest River Forums1427132660.188446.jpg
Old 03-23-2015, 12:48 PM   #3
Sbryant's Avatar
Pics largerClick image for larger version
Name:	ImageUploadedByForest River Forums1427132888.420663.jpg
ID:	72010Click image for larger version
Name:	ImageUploadedByForest River Forums1427132904.127784.jpg
Old 03-23-2015, 01:42 PM   #4
abjb's Avatar
GOOD to see FR is on top of this design problem
Our 2012 (built 4/11) had this problem.
Walmart camped last year with a 2014, his was worse than ours. He hadn't noticed it, said he would be back at his dealership in a few days, hope he made it.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 03-23-2015, 02:08 PM   #5
VinceU's Avatar
You are treating the result, not the problem. Thr cause is the water heater poor foundation it allows the compartment floor to bow excessively and that forces the outer panel to shear its screws and become loose. This has been happening since 2009 or 10. This is a warranty problem, can't believe still built like that.
Old 03-23-2015, 07:43 PM   #6
We had the same problem last year. Noticed the problem once we arrived at the RV Park. Went to the hardware store and bought screws and re-secured the panel temporarily until we returned home. Called the dealer and set up time for them to fix it. Once the dealer service looked at the problem they said an additional support needed to be welded in. A bracket was missing from when the coach was built. By the way we have a 2014 377 XL.
Scotty2 is offline   Reply With Quote
Old 03-23-2015, 10:35 PM   #7
Sbryant's Avatar
Lots of GT's have reported this problem, and they've fixed it in various ways. I don't believe that there was any "missing" bracket, just poor engineering.
Old 03-23-2015, 11:45 PM   #8
Crockett's Avatar
looks like it needs some structural members between the outriggers he tied his strapping to. i hope this isnt some composite floor. that might explain why FR hasnt addressed this. although it appears the outriggers, or at least one is there.
Crockett is offline   Reply With Quote
Old 03-24-2015, 04:07 AM   #9
abjb's Avatar
Here's a nice thread from 2012 with pictures of the cause.
Georgetown Water Heater Support Mod
I didn't use this repair method, I used the external support method.
ab&jb
2012 Georgetown 360
Old 03-24-2015, 08:12 AM   #10
Sbryant, Thanks for the pics. Now I see what you did. I originally thought you used the metal strip as an angle bracket at 90 degrees and attached it behind the outer panel where the original "L" brackets attached, and then to the bracing channel that runs parallel. I had seen the post from 2012 but that whole process, though probably the best fix, is way beyond my mechanical abilities. Thanks again for posting your much simpler fix.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
heater, repair, water, water heater
