Old 06-05-2017, 10:11 AM   #1
Water Heater Switch
Checking to see if anyone has had a problem with the electric switch on the hot water tank locking or stuck in the on position. Seems like a pain having to remove the tank just to change the switch.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is online now   Reply With Quote
Old 06-05-2017, 10:24 AM   #2
wmtire's Avatar
It happens a good bit. You don't have to remove the tank. You may have to remove the gas line in front of it, to get better access. You just stick a flat head screwdriver in at the top or bottom, depending on how you can get to it.
I just posted a pic the other day. let me look at my older posts.
2011 Flagstaff 831 RLBSS
Old 06-05-2017, 10:26 AM   #3
wmtire's Avatar
Try posts #11 and 17 here:
http://www.forestriverforums.com/for...ml#post1520481
Old 06-06-2017, 09:30 AM   #4
Thanks wmtire! I archived this thread for future reference. As far as my switch goes, I sprayed the black switch with WD-40 and let it sit for a couple of hours. It now works again. If I have a problem again, thanks to you I'll just put a new switch in.
Old 06-14-2017, 10:48 AM   #5
Thanks Again! to wmtire for pointing it out to me how to replace my water heater electric switch. I guess the WD 40 only un-froze the shot switch. With tax at a local RV dealer, $4.80.
Old 06-14-2017, 10:59 AM   #6
You could also install a switch inside.
New water heater outlet box to hold a "real" 110VAC outlet (not the crappy RV type):
Hole for new inside pilot light switch:
Electrical box in hole:
New switch installed:
Wiring and switch part number attached.
2011 Traverse LT, 3.6L, FWD
Old 06-15-2017, 02:00 PM   #7
Thanks rockfordroo! I have seen some other posts in the past on putting in a real switch too.
heater, switch, water, water heater
