Old 05-16-2015, 08:41 AM   #1
Fr27davis's Avatar
Water heater switch
Has anybody ever moved there electric water switch from the outside of the heater to the cab? I have a dual power suburban 6 gal heater, and do a lot of different types of camping, from boondocking to full hook ups, and I feel that I am going to break the latch going into and out of the water heater.
Also one more question, has anybody ran the coolant lines to there engine to get hot water while they are running, my truck they are not hooked up.
2013 Georgetown 35dds
Matt
Fr27davis is offline   Reply With Quote
Old 05-16-2015, 09:20 AM   #2
Sbryant's Avatar
I put an inline rocker switch for the electric water heater - connected to the circuit breaker - mounted on the circuit breaker cover. Used a lighted switch so I can tell when it's on or not.
Sbryant is online now   Reply With Quote
Old 05-16-2015, 10:17 AM   #3
Fr27davis's Avatar
Will to propane still work if the power is off?
Old 05-16-2015, 10:39 AM   #4
mark0224's Avatar
On mine there is an outlet on the inside that the water heater plugs into, I'm going to re wire it so it has a switch going to the outlet and just leave the outside switch on so I can just turn it on from inside. To answer your last question yes the gas works without the electricity it only requires the 12 v from the battery to ignite.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 05-17-2015, 01:27 AM   #5
Leave the on/off switch at the heater in the on position and just turn off the circuit breaker inside the panel when using propane to heat the water.
2002 GMC Sierra 2500HD Duramax
2008 Rockwood Sig Ultra Lite 8315SS
Livin the Life is offline   Reply With Quote
Old 05-17-2015, 07:17 AM   #6
WDK
WDK's Avatar
Water heater switch
Convenient idea but a circuit breaker is not meant to be as switch no matter how rare.....safer to take trouble and wire a switch in series.
WDK
WDK is offline   Reply With Quote
Old 05-17-2015, 07:35 AM   #7
Although mine is a fifth wheel, I just replaced the Girard on demand water heater with a standard Suburban 6 gallon gas/electric. I mounted a switch with indicator light in the cabinet under the sink. On the last fifth wheel I always used the breaker to turn it off. I will still use the breaker when I winterize so as to avoid turning it on before it is filled with water.
Filthy Beast is offline   Reply With Quote
Old 05-17-2015, 09:55 AM   #8
No offense WDK, of course the circuit breaker should not be used like a light switch when entering and leaving a room on a daily basis but the occasional turning it on/off when not in use will not harm the breaker, that's what its for.
If one has the skills or money then certainly wire the switch in a convenient spot and use it.
In addition Fr27davis if your concerned about breaking your, I'm assuming plastic hot water heater access spring "latch", you could replace it with a metal one. They're pretty cheap.
But again, if you have the time, skills or money, go for the additional switch.
Old 05-17-2015, 09:58 AM   #9
Fr27davis's Avatar
Thanks everyone.
Old 05-18-2015, 11:48 AM   #10
WDK
WDK's Avatar
No offense taken though the only reason the breaker should be turned off is for the safety or maintenance but using it as a switch at anytime is NOT what it is for....it's designed to trip that circuit when there is a current over load....the element is heated to the point where it bends and trips the breaker and the more you mess with the less serviceable it becomes....but we do a lot of things we are not suppose too.
WDK
heater, water, water heater
