09-24-2017, 12:54 PM
Stupac7
Water Heater "Thing"
If you can see the attached photo, I am a new to me RV owner of a Georgetown, 350 and I was practicing my skill at draining the hot water heater. I watched a Forest River video and the guy simply pointed to the plug to remove water. Well, I removed plug and all this came out with a bunch of what looked to me like white calcium deposits. Should I look to replace this part? It is all pitted. Or is this just a natural cycle of things in the water heater?
09-24-2017, 12:56 PM
Scoundrel
Anode rod. $13.00 bucks.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
09-24-2017, 12:57 PM
It's the anode rod, keeps hw tank from corrosion. It's connected to the plug, you can get replacement at an rv store. Usually replace yearly, for best protection.
Bill and Gail
2016 Sunseeker 3010DS
V10 6 speed transmission
2017 Ford Fiesta toad
09-24-2017, 12:59 PM
That anode rod has a ways to go before replacing is necessary. Looks like it's doing its job.
09-24-2017, 01:04 PM
Stupac7
Thanks bunch people. This is a great forum.
09-24-2017, 01:22 PM
That anode rod is fine and has a lot of life left.
No need to replace it yet.
09-24-2017, 01:31 PM
Just as confused as you
X2, as others have said no need to replace it. Just flush the water heater while the plug/anode is out and you will be good.
Richard & Jill
09-28-2017, 07:19 AM
Those bits of debris can migrate to the filter screens on the toilet line and the sink faucets. There is a check valve on the cold water line to the water heater that opens when the water is being added to the water heater. The particles swirl around in the tank and a few can be siphoned back into the cold water line and then migrate to various locations. They can also migrate in the hot water supply. Many folks think this debris is from the RV park water system which can also happen. But those little white scales are from the anode. Replacing the anode annually helps. Once the rod starts to break down it seems to accelerate. Shamefully I once removed mine and all that was left was a bare rod! I have had to clean all my water diffuser screens several times over 5 years. Others have posted much the same.
09-28-2017, 07:36 AM
Plenty left on that rod. Good to go.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
09-28-2017, 07:48 AM
Since you have it out I would replace it, Replace it annually no mater what
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
09-28-2017, 08:12 AM
Just to explain a little further. The anode rod is made from a sacrificial metal meaning basically it will corrode before the metal in the tank, thereby protecting the tank. The rate at which it corrodes is dependent on the quality of the water. Since many campgrounds are on well water, the water tends to be more corrosive as less conditioning is done on the water. In addition when the anode rod corrodes, the white crud that falls off sits in the bottom of the WH and can be drawn into the water lines and clog valves and spigot screens. I recommend removing it at least annually to both drain the WH and check the rod.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-28-2017, 08:34 AM
Stuart, since you obviously have the Suburban water heater, I would suggest you watch the 5 instructional videos that Suburban provided us here. The very first one explains the anode rod.
http://www.forestriverforums.com/for...ml#post1527599
Also this FAQ may help in the operation of your water heater:
http://www.forestriverforums.com/for...ore-36197.html
Hope this helps
2011 Flagstaff 831 RLBSS
