Old 04-22-2016, 12:15 PM   #1
Water help
Filled fresh water tank. No water coming through. Is there. Valve or breaker I need to check.
Truckdogg4 is offline   Reply With Quote
Old 04-22-2016, 12:21 PM   #2
clr
I would first check the winterize valve position. Should be in the normal position to pull water from the tank. If the tank is in the winterize position it will be sucking air from the tube used to winterize the unit. If that is OK you may have to prime the pump if all else fails.
clr is online now   Reply With Quote
Old 04-22-2016, 12:23 PM   #3
Mr. Dan's Avatar
Did you turn on your water pump?
Can you hear the pump running?
Is your "anti-freeze sucker valve" closed?
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
water
