09-17-2011, 05:29 PM
Water in Fridge
In our 2008 378TS we have Dometic RM 1350 fridge and we seem to be constantly mopping up water from behind the crisper trays in the fridge. It doesn't seem to matter if it's hot or cold outside, the water seems to be there daily. I have noticed that we aren't getting much of a temperature fluctuation on the display, so am somewhat baffled as to the cause. I have blown out the drain both ways, and have adjusted the inner tray so that runoff goes out the drain hole. Any suggestions?
09-17-2011, 08:29 PM
Lottery Non-Winner
You said you cleaned out the drain, so it should be draining. But the fact that it is collecting enough to keep you "constantly mopping" has me thinking perhaps the seal doesn't seal and the cool walls are condensing the moisture in the air. Check your seal. But I have no idea why the drain line isn't draining seeing how you have already cleared it.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
09-22-2011, 06:55 PM
Still stumped
Seals seem to be good. No excess humidity noted in fridge. Defrosted fridge just to be on the safe side and noted no real change, still getting water on bottom of fridge. Also the collection tray is icing up. Installed a fridge fan to circulate cold evenly....no real change.
09-22-2011, 07:25 PM
Try closing the door on a dollar bill in several different areas. There should be a lot of resistance when you try to pull it out. If there is little resistance the door seal is suspect or the door is out of adjustment. Also check to make sure the top of the seal has a good contact surface. If the door has sagged it may only be catching a small part of the frame. Also check the top portion of the fresh food section, if the insulation under the freezer floor has become saturated it will make the top of the refrigerator very cold and a lot of water can condense and drip.
09-22-2011, 07:29 PM
it would have to be an American dollar. We only have the loonie in Canada.
Terry/Bernadette Lily the Yorkie 2019 Dodge Ram Sport 1500 2019 FR Vibe 28RL
09-22-2011, 08:17 PM
BETTER USE AT LEAST A $100 BILL ON THE DOOR SEAL TEST. THE $1 BILL HAS GOTTEN SO SMALL YOU WILL HAVE TO USE TWEEZERS TO HOLD IT! IF THIS WERE NOT TRUE IT MIGHT BE FUNNY!
09-23-2011, 11:36 AM
water in bottom of refridgerator
On the double doors the seal flap is sticking open. After closing the first door reach in a pull the flap out, then close the second door.
09-25-2011, 11:54 AM
I don't know whether to thank you or curse you Havasu, but...yes, the flap is not closing completely. It seems to be catching on the bottom moulding. I'm not sure of the cause: door sagging, flap attached too low, bottom moulding in need of a little trimming, or what. It will take a while to sort and resolve. I will keep all posted.
Chuck
09-25-2011, 04:36 PM
water in fridge
I had the same problem with water collection in bottom of refrigerator. On humid days it got so bad water ran down and shorted the gas detector located below the unit. I finally noticed the flap sticking and now, by habit, check to see that it is in place before shutting the right door. Never a water problem since!
06-03-2012, 06:13 AM
Chuck
I have the same problem, did you find a solution?
06-03-2012, 07:36 AM
hate to say this and not sound rude but if you read any of the posts above you would have gotten the solution
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
06-03-2012, 08:20 AM
I think he ask for a (Solution) not a (Band Aid)! Youroo!!
06-03-2012, 10:28 PM
I took the black fitting on the bottom ledge of the fridge off and found it full of water. I adjusted it and put sealant around it to keep it from filling up with water. I continue to ensure that the left door flap has closed properly since it fails to close occasionally when the door is full of heavy items. The only other minor thing i did was put a small piece of tubing on the tray spout so that it fit in the drain hole better.
06-04-2012, 06:56 AM
CVan, I think you may have solved the problem with the flap. I never thought that too many heavy items in the door would cause the bottom of the door to drag enough to keep the flap from closing properly. I will ask the DW to put only light stuff in that door and see how that works. Thank again for a SOLUTION!
