Old 12-26-2015, 07:06 PM   #1
rparker3040's Avatar
Water in frig freezes
I have a 2014 Georgetown 377xl with a Frigidaire French door bottom freezer residential refrigerator. There is a large coil of tubing in the refrigerator part in the bottom left behind a cover that cools the water before it is dispensed from the refrigerator door. The water in the tubing freezes so that no water can be dispensed. The temperature setting for the refrigerator is 36 degrees. Nothing else in the refrigerator freezes, not even water bottles that are stored in the refrigerator. When I thaw out the coiled tubing water dispenses through the door with no problems. Has anyone had this problem? Any answers or solutions would be great appreciated.
Bob Parker
rparker3040 is offline   Reply With Quote
Old 12-27-2015, 05:26 AM   #2
DarrenK's Avatar
I've never had that problem, but you might try giving Frigidaire a call. They probably have a hotline phone number on a sticker inside somewhere...
DarrenK is offline   Reply With Quote
Old 12-27-2015, 05:48 AM   #3
cjd10's Avatar
I had the same problem with mine. Set the temp higher on the freezer a little and haven't had it happen since.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is online now   Reply With Quote
Old 03-21-2016, 10:05 PM   #4
SimoRandy's Avatar
Send a message via AIM to SimoRandy
Same problem with no water. Setting is at 5 but can only go up to 6.
Randy S.
2016 Georgetown XL 369 & 2013 Jeep Wrangler
SimoRandy is offline   Reply With Quote
Old 03-22-2016, 06:03 AM   #5
I keep my refer at 40 and the freezer at 0. 36 seems a little low for the refer.
Georgetown XL 377TS
USAF-- CMSGT Retired.
georgew48 is offline   Reply With Quote
Old 03-22-2016, 02:06 PM   #6
Happily Retired Member
My vegges and fruit get too cold in my residential refrigerator with factory settings. I set the refrigerator to 44 deg and it is plenty cold. This may help your water freezing issue.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
water
