Old 06-20-2016, 03:43 PM   #1
Water in Inverter bay 364
Going through Seattle it was raining pretty good for a while, shortly after the inverter GFI kicked and shut down the fridge.
Found this in the bay, water splashed up and went into AC outlet, every time I plugged in and reset GFI it would trip. Blew it out with my blower and the next day it was fine. Not sure how this much water could have got in, there is the drain tube but I can't imagine it going up.
On a positive note, the rig is awesome, plenty of power pulling our Pilot up the hills from CA to Vancouver.
Enjoy the pics
2016 364TS
Kevin M. is offline   Reply With Quote
Old 06-20-2016, 06:40 PM   #2
cjd10's Avatar
Have you used the black tank flush? Not sure how the 364 is laid out but on my rig the line on the black tank flush cracked and was pouring water into the bay with the inverter
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 06-20-2016, 06:41 PM   #3
Yes I have used it, however not on this leg of the trip. It was definitely water from the rain/road.
2016 364TS
Old 06-20-2016, 08:04 PM   #4
At night, put a light in the compartment and shut the door, then check for any light leaks. Worked for me.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 06-20-2016, 10:34 PM   #5
toolman_57
The front water heater valves share the same bay. Maybe one of the valves or water lines is leaking.
toolman_57 is offline   Reply With Quote
Old 06-20-2016, 10:49 PM   #6
I figured it out, we drilled a hole when we were running new romex for the inverter mod, but ended up finding the main line for all AC outlets, we didn't plug the hole back up, you can see it to the right of the inverter.
2016 364TS
Old 06-21-2016, 07:57 AM   #7
toolman_57
I like it--We're now calling it "the inverter mod"
Old 06-21-2016, 11:10 AM   #8
cjd10's Avatar
Glad you found it before the inverter got fried.
Beautiful pictures btw
Charleston SC
Old 06-21-2016, 11:46 AM   #9
yes, I'll post more details about the mod shortly
2016 364TS
Old 06-21-2016, 11:47 AM   #10
Yes I agree! Glad the gfi did its job, thank you!
2016 364TS
inverter, water
