Old 07-14-2013, 03:15 PM   #1
Water Leak
I was doing some maintenance on my Georgetown 2012 378XL and found a small puddle of water in the fresh water holding tank compartment. I took a dry rag and dried it up the next day same thing. I could not find where it was coming from till I took off the slide door out and there it was a plastic sediment filter at the water pump that had vibrated loos and was dripping water. So I took it off and cleaned the screen and put some pipe tape to keep it from coming loose again. All is good now.
sandpiper is offline   Reply With Quote
Old 07-15-2013, 02:16 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
If you don't use anti-freeze through your pump you'll find out it will freeze and crack to pieces. Found that one out firsthand the first year I used the air compressor to blow out the lines. I took a silver Sharpie and wrote myself a friendly reminder on the access panel to be sure to dump it before winter storage.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
