Old 08-20-2015, 01:50 PM   #1
Water leak
I have a 2012 351 Bunk House...
The carpet in the bedroom that shares the wall with the bathroom is soaking wet(mainly inside pocket door slide area) I cannot find the source of the leak. Inside shower panel is wet, but all pipes are dry. Also, doesn't appear the shower pan is leaking while taking a shower. Not sure where to look undercarriage outside to follow plumbing underneath. Any help would be great!Click image for larger version
Name:	ImageUploadedByForest River Forums1440096443.641888.jpg
edmonh is offline   Reply With Quote
Old 08-20-2015, 04:10 PM   #2
Figured it out! Simple washer change at shower faucet.
Old 08-20-2015, 04:11 PM   #3
HookupAndGo's Avatar
I noticed on mine that the top of the shower cassette was not sealed. So, if water is splashing as you shower, plus the condensate on the walls above the shower, that may be where the water is coming from.
2013 Georgetown 351
Much more significant other....
2 Kids and a dog that rules!
HookupAndGo is offline   Reply With Quote
Old 08-20-2015, 04:14 PM   #4
Thanks, Hookup! It was a worn out washer at hot water valve. Quick fix, but not being handy it took me awhile to figure it out😀
Old 08-21-2015, 06:25 PM   #5
I would still recommend you check the top of the shower -- everyone. I was really surprised that mine had minimal sealer.
2013 Georgetown 351
leak, water, water leak
