Old 08-01-2012, 12:43 PM   #11
I had the same problem with my 2011 327. When the dealer fixed it, he discovered that when the slideout was assembled; they forgot to remove the protective plastic wrap from the top panel before assembly. After everything was sealed up, they removed the plastic which meant that the sealer between the roof and side of the slideout was sitting on top of the plastic and not attached to the roof panel. Water had no trouble running under the plastic and came pouring in over the dining table.
Phil
pmsherman is offline   Reply With Quote
