Old 06-23-2016, 09:27 PM   #1
Water leaks
I have a '07 Georgetown XL 378TS. The issue is two fresh water leaks. One is leaking from the bottom of the bay where the water heater is located. The second leak is above the LP tank. I think it is the FW tank. The low point drain is located there. I went under the rig, and cannot locate the water line. How do I find the leak? Last time we used the rig, no leak.
badge2283 is offline   Reply With Quote
leak, water, water leak
