Old 04-11-2011, 11:55 AM   #11
Lou,
Where are these white plastic water flow restrictors you spoke of? My bath sink has very low pressure.
Larry
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-11-2011, 12:19 PM   #12
Herk7769's Avatar
Remove the aerator screen FIRST and make sure there is no crud clogging the screen. The white plastic disk with the small diameter hole is the flow restrictor. It can be removed to see if it is the problem. If it is, you can carefully enlarge the hole till you get the flow you want.
I juts removed mine and keep it in a plastic bag under the sink. When dry camping, I want the restricted flow for water usage control.
HAM CALLSIGN - KC3FFW
Old 04-11-2011, 01:03 PM   #13
Brand new trailer so I don't think crud is my problem, although never say never.
My main problem (related) is that I can't figure out how to remove the faucet end cap housing the screen. It pushes up and pulls down and twists in either direction and I have never seen anything like this. Seems to be designed to NOT be removed which makes no sense at all.
Old 04-11-2011, 02:55 PM   #14
Herk7769's Avatar
Yikes! Photos now please.
Crud could have been in the lines from when they drilled the probe holes in the fresh water tank.
Old 04-11-2011, 05:51 PM   #15
Originally Posted by herk7769 View Post
I did remove the white plastic water flow restrictors in the bathroom faucets (shower and sink) but there is not one in the kitchen that I could find. There is not one at all for the toilet.
I am still leaning toward the filter being clogged. Mine is getting yanked completely as soon as its back from being inspected. I am only using the Wal-Mart inline hose filter now.
Well, sure enough it was the water filter that needed replacing. I guess what sure have been easier to diagnose was made more difficult because the filter was supposed to last six months. I'm sure it hasn't been six months. I replaced it with a less restrictive (cheaper) filter. Hey, that fixed this problem. Thanks for all who gave advice.
georgetown50 is offline   Reply With Quote
Old 04-11-2011, 05:58 PM   #16
sherdep's Avatar
get one with a 5 micron filter with charcoal - the lower the micron the lower your pressure will be because the more it filters and the harder the water is to get past the filter
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-11-2011, 08:08 PM   #17
Lawfive's Avatar
Water Pressure
Another spot to check, like enough haven't been identified, is a small filter near your water pump. If you are on city water it doesn't affect things but running off your fresh water tank will be impacted. I noticed mine one day. Unscrewed it and found it about 75% full of PVC shavings. They were obviously from the manufacturing work on plumbing in the rig. Glad the filter trapped them before they hit any fixtures but over time they would have built the base for a clog or pressure problem. Best case would have been a premature failure of the water pump.
2007 391TS UFO Chassis
Lawfive is offline   Reply With Quote
Old 04-11-2011, 08:14 PM   #18
Herk7769's Avatar
[QUOTE=georgetown50;95421]I'm sure it hasn't been six months.QUOTE]
How does that go? "Results not typical."
