Old 10-14-2015, 12:22 AM   #1
Glamping's Avatar
Water Pressure Problem
We have a 2012 Georgetown 360. Last week while dry camping, the kitchen sink started to lose water pressure. Hot and cold. All other faucets in the coach work fine. I plan on a hot water tank flush this weekend but was wondering what might be causing the water pressure issue.
Rich
Connie and Rich
Surprise Az
2012 George Town XL 360
2013 Can Am Maverick
Glamping is offline   Reply With Quote
Old 10-14-2015, 12:52 AM   #2
jergeod's Avatar
check the screen on the end of your faucet, most likely it is full of junk.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 10-14-2015, 02:16 AM   #3
ColoradoRick's Avatar
x2...I've found Styrofoam balls and wood chips in mine.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-14-2015, 09:27 AM   #4
Glamping's Avatar
Thought about thay too but didn't find much. Probably will pull the assembly out and check for debris.
Connie and Rich
Surprise Az
Old 10-15-2015, 11:17 PM   #5
If you have the same faucet as we do in our Pursuit we had a similar problem. Lines going to the faucet were clear and had great flow. The line going up to the hand held end, has a check or flow valve at the line out of the faucet to flex hose. This valve was bad and would hardly let a trickle out. Removed and have full flow.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 10-16-2015, 03:17 PM   #6
Glamping's Avatar
Thanks ResQfrog, will check that out this weekend.
Connie and Rich
Surprise Az
Old 10-16-2015, 03:53 PM   #7
abjb's Avatar
+1 we had the same problem.
Bought Aug 2012 most water outlets clogged by Sept. 2012.
LOTS of little chunks of fresh water tank left in the tank during construction.
Took a couple of yrs to get most of it out.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
pressure, water
