Old 04-17-2011, 05:07 PM   #1
Water pressure regulators
I'm looking at a new pressure regulator, as I only have the one I got for free when I bought my MH. My question is, are the $10.00 ones at CW reliable, or should I get one that is adjustable for pressure and has a gauge? Are the ones with adjustable pressure and volume needed, or overkill?
Any brand or models that hold up better or are recommended?
Thanks, Randy
blue283 is offline   Reply With Quote
Old 04-17-2011, 05:11 PM   #2
tmmar's Avatar
I had the $10 models for quite a while and finally got fed up with the low water pressure. These regulators severly limit the water flow. Got an adjustable model and was able to set the adjustment to a point where the pressure was much better. I am sorry that I waited so long to get the adjustable model.
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-17-2011, 07:49 PM   #3
Did you get the one with adjustable volume, or did adjusting the pressure improve the flow? Is the standard around 45psi?
2010 Georgetown 300 FWS
2003 Jeep Liberty
Old 04-17-2011, 10:33 PM   #4
I just purchased the Valterra with the guage and the setting for flow. The cheap ones simply restrict the water flow too much. Got it from camping World...
polkatronron is offline   Reply With Quote
Old 04-18-2011, 07:13 AM   #5
KyDan's Avatar
Take a look at this thread on adjustable water pressure
regulators.....
http://www.forestriverforums.com/for...tor-11381.html
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 04-18-2011, 01:06 PM   #6
Thanks for all the info..... now I just need to order one!
Randy
2003 Jeep Liberty
Old 04-18-2011, 02:08 PM   #7
Send a message via Skype™ to scubieman
What PSI should our water pressure be at?
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 04-18-2011, 06:16 PM   #8
SCannon's Avatar
Randy I bought a new TT last year and my family bought a starter kit as a gift, all of which I use. In the kit was an inline requlator which I see sells of between $15-$20. I soon realized that not only did it restrict pressure but it reduced water flow to about 3-4gpm. You can get a better show with a water pistol.
I recently purchased a Valterra adjustable with guage for $ 52.00 from Camping World and it works very well. See the pictures attached. This was a test so after the short 4ft drinking hose I attached a plain garden hose for the test only. The short hose lets me attach to the campground supply and the lift the water regulator off the ground using a velco strap to attach the short hose to the spigot post.
I can adjust the pressure to 40-45 and still receive a flow of about 12-14gpm. This lets you adapt to campground pressure which varies as some use wells and others use city water.
S Cannon
SCannon is offline   Reply With Quote
