Old 07-21-2016, 05:52 PM   #11
Originally Posted by D_B Travelers View Post
tamdle, once they put water in the holding tank and you turn on the pump, go around and run water out of each faucet (don't forget the outside shower too). Run both hot and cold to completely fill the lines and water heater tank with water. Then do the rest of the PDI with the pump still on and the lines pressurized. If you hear it cycle, then there is a leak somewhere. Otherwise
Thanks DB, you guy are great!
Have a great day...
tamdle is offline   Reply With Quote
Old 07-21-2016, 09:24 PM   #12
X2 on the regulator. I always use one and it is adjustable. When flushing the black water tank, I open the drain and turn on the water - hot and cold from the outside shower which I connect to the flush inlet. I then adjust the pressure to unrestricted by using a screwdriver to maximize the pressure. When finished, I adjust it back down to 30 psi. or a little less.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
johnruff is offline   Reply With Quote
Old 07-21-2016, 09:40 PM   #13
Thanks John for your advice, a water pressure regulator with a gauge is already in my tool kit.
pdi, pressure, water
