Old 01-31-2011, 07:15 PM   #11
MotocrossCamper's Avatar
Originally Posted by kenandterry View Post
Given all the different sources for water that we as campers are presented with at all the different campgrounds, it's also possible the water contains substantial amounts of calcium, rust, sediment or whatever. All of which could clog the small openings in the aerator. This sounds like the most likely culprit gievn that the kitchen and outside taps work.
CLR......available at any good hardware store, is great for cleaning these. Also great for cleaning the shower heads in your RV AND at home.
We clean all of ours in CLR also. We have also noticed that it isn't uncommon to find little pieces of sand and grit in there if you use a campground that pumps from a well. Even with a filter we have still had some get through.
MotocrossCamper is offline   Reply With Quote
Old 02-04-2011, 01:00 PM   #12
Thank you, I will try CLR
fidaddy66 is offline   Reply With Quote
Old 02-04-2011, 10:27 PM   #13
jsutherl's Avatar
This might be a good excuse to put in an aerator valve. We have one installed in the bathroom of our 350DS.
You unscrew your aerator and screw this little water saver on. It has a plastic stick that hangs down from the center of the aerator. Water will only flow when you push or pull the stick gently to the side.
For instance when you wash your hands no water flows while your soaping and scrubbing your hands.
We got ours at Home Depot. This is the only place I could find them on-line so that you could see what I'm talking about. I don't know anything about this web site.
Instant OFF Water Saving Automatice Faucet Control | E3 Living
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 02-04-2011, 10:28 PM   #14
jsutherl's Avatar
Also if your aerator is hard to clean, just grab another one at home depot or lowes. Take it in with you when you go and they'll make sure you get the right one. They're only a couple bucks, heck buy a handful and keep them in a drawer.
Old 02-12-2011, 06:50 AM   #15
I have had that happen also and took out the aerator to clean but that was not the problem. The problem was under the single lever handle.
You push it left for hot and right for cold and there are two washers and two little springs under there and one of the little round O rings came loose and wounldn't let any water pass through.
Now I'm not saying this is your problem but if you can't fix it by cleaning the aerator that might be another place to look.
Now while I have everyones attention, does anyone know where to get replacement shoower faucet knobs? They are ony plastic and when I turned the hot water on it just snapped. I went to a couple rv dealers no luck. Left a message for Glenn in the parts dept of FR no call back yet.
They are made by Dura Faucet Manuf. I can order the whole faucet set up, but I only need the knobs in fact I only need one. Oh I also been to Lowes and HomeDepot. I'm out of ideas now so any help you can give will be appreciated.
Thanks.....Joe
JDickson is offline   Reply With Quote
Old 02-12-2011, 07:24 AM   #16
I worked at home depot for 3 years and they do have universal handles that will fit most everything. Take the good handle with you.
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
Old 02-12-2011, 08:11 AM   #17
The aerator on my bathroom faucet pushes up and down and spins and I can't seem to unscrew it. Anyone else have anything like this?
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 02-12-2011, 10:46 AM   #18
Send a message via Skype™ to scubieman
Picture?
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 02-12-2011, 05:26 PM   #19
Water was coming out of the vents on outside of the coach. It is behind the refrigerator. Looks like a little plastic cap has a hole in it. Is this easy to replace? Also, a strong propane odor coming from the same spot. What do you think is wrong? Is this dangerous?
Ginger Compton is offline   Reply With Quote
Old 02-12-2011, 05:42 PM   #20
Herk7769's Avatar
Water coming out of that hose is normal. It the the condensation drain for the fridge. Just make sure the hose is routed to the outside of the fridge vents so the water does not pool in the camper.
Smelling propane there is not normal.
HAM CALLSIGN - KC3FFW
