Old 01-31-2011, 02:32 PM   #1
Water Problem
Hello,
I have a 2010 Georgetown 330ts, the water faucet in the bathroom is not working! I have looked for a shut off all around the coach and have come up with nothing, all other faucets are working, can anybody help me?
fidaddy66 is offline   Reply With Quote
Old 01-31-2011, 02:57 PM   #2
MtnGuy's Avatar
Is it possible your aerator is stopped up ?? You can unscrew that from the faucet and see if there is sediment restricting the flow.
Old 01-31-2011, 03:48 PM   #3
Send a message via Skype™ to scubieman
Is it both hot and cold water?
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 01-31-2011, 04:08 PM   #4
Yes it is both tha hot and the cold
Old 01-31-2011, 05:23 PM   #5
MotocrossCamper's Avatar
+1 I have had that problem before, it doesn't take much.
MotocrossCamper is offline   Reply With Quote
Old 01-31-2011, 05:38 PM   #6
What did you do to fix it?
Old 01-31-2011, 05:45 PM   #7
Thanks, I will try that.
Old 01-31-2011, 05:46 PM   #8
Unscrew the the little strainer off the very end of the faucet and clean it all out. It is just a little plastic piece that restricts water flow so you don't use so much every time you use the faucet. Just run it under some water and scrub it off a little.
Old 01-31-2011, 05:54 PM   #9
Thanks I will try that!
Old 01-31-2011, 06:18 PM   #10
kenandterry's Avatar
Given all the different sources for water that we as campers are presented with at all the different campgrounds, it's also possible the water contains substantial amounts of calcium, rust, sediment or whatever. All of which could clog the small openings in the aerator. This sounds like the most likely culprit gievn that the kitchen and outside taps work.
CLR......available at any good hardware store, is great for cleaning these. Also great for cleaning the shower heads in your RV AND at home.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
