Old 01-26-2015, 10:56 AM   #1
MarkAnne's Avatar
Water problem. 2010 337DS
I'm out on my first big trip after purchasing this MH in September. I have a wet spot in the carpet under the dinette table. At first I thought it might be coming from the AC. It's not dripping from above because it's under the table. I actually stopped running the front AC to diagnose. No rain here in AZ. Can't find any leak from nearby kitchen sink and nothing evident under the MH. The carpet will not dry despite vacuuming with wet dry vac repeatedly. No other signs of water in MH. Any thoughts or experiences?
2010 Georgetown 337 DS
MarkAnne is offline   Reply With Quote
Old 01-26-2015, 11:24 AM   #2
Iggy's Avatar
1. Someone is dumping a glass a water there to drive you crazy?
2. Do you have a dog or cat?
3. Check under the table for a leaking pipe?
4. Any missing ice cubes from your glass?
All in gest Have no idea where your wet spot may be coming from what you have said.
Iggy is online now   Reply With Quote
Old 01-26-2015, 11:31 AM   #3
fonzie's Avatar
What is under your dinette seats? water pump? might have a leak when running water?
Fonzie
Old 01-26-2015, 01:53 PM   #4
MarkAnne's Avatar
There is no plumbing under the dinette. It's actually in my slide.
Old 01-26-2015, 02:08 PM   #5
Mojojojo's Avatar
You probably don't want to hear this but it could be leaching up from the wood of the slide being soaked from a leak you aren't aware of. Use the blunt end of a screwdriver to see if the top and or bottom of the floor is soft anywhere.
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 01-26-2015, 03:43 PM   #6
MarkAnne's Avatar
Found it finally! Leak under kitchen sink water supply line. Now it will dry out!
Old 01-26-2015, 09:13 PM   #7
Mojojojo's Avatar
Thank the Rv gods that was all it was, was it getting a cross the floor under the carpet?
Old 01-26-2015, 09:45 PM   #8
MarkAnne's Avatar
It did travel under the slide but I think it will dry out and be ok.
Old 01-27-2015, 01:20 PM   #9
We have a 2010 337 also and we have ocasionly had water run from under bathroom wall will traveling and it seems to come from a toilet water line at floor in rear of toilet that loosens over time. We tighten it up by hand and all is fine for a while. We do this about once a year.
DAPYES is offline   Reply With Quote
Old 01-27-2015, 05:59 PM   #10
Team Bleu
A/C water running off the roof and possibly found a way down the slide wall and getting in behind the rubber
DBsRedVett is offline   Reply With Quote
water
