08-26-2015, 02:23 PM
Water problems
I am getting hard white residue in my toilet and faucets. I have flushed the water heater and fresh water tank. I'm going to flush all the lines this weekend. Does anyone have other ideas of what to do?
2010 Georgetown 337 DS
08-26-2015, 02:50 PM
I see you have a 2010, I'd say construction debris should already be cleaned out.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
08-26-2015, 03:45 PM
Retired US Army CW4
[QUOTE=MarkAnne;965568]I am getting hard white residue in my toilet and faucets. I have flushed the water heater and fresh water tank. I'm going to flush all the lines this weekend. Does anyone have other ideas of what to do?
Had the same problem. Pull the anode rod out of your water heater. You'll most likely find that it has completely worn out and the bottom of your water heater tank is coated with the same white residue that is clogging up your toilet line and faucets. I was pulling the connector off the back of my toilet and the screens out of the faucets every time we went out to clean them out. After flushing the tank out and replacing the anode rod it has been trouble free ever since.
2014 Georgetown 329DS
Towing a 2011 Jeep Wrangler JKU w/ReadyBrake
Yorkie guard dog on the dash
08-26-2015, 03:55 PM
[QUOTE=Tom and Kat;965654]
Didn't know hot water was supplied to the toilet?
TURBS
2011 32bhok Sabre
08-26-2015, 07:38 PM
[QUOTE=TURBS;965664]
TURBS
2011 32bhok Sabre
Of course it isn't but somehow that residue from the water heater tank that gets into the faucets and clogs the aerators also gets to the toilet and clogs it up at the input internal screen (310 toilet). Happened again to me on my last trip. When disconnecting toilet it back flushes most of the residue and I use a toothpick to finish cleaning out.
08-26-2015, 08:13 PM
[QUOTE=bubbles;965900]
No possible way for debris in the wh to get to the toilet.
TURBS
2011 32bhok Sabre
08-26-2015, 08:24 PM
I would think is just may be bad water where ever you are hooked up at.
Have you checked what the water looks like coming from the campground spigot?
08-26-2015, 08:27 PM
Do you use a water softener? It could be lime scale from hard water. I use one because a lot of the parks have very hard water.
08-26-2015, 10:46 PM
Run vinegar through lines. It brakes up calcium deposits in the lines.
08-27-2015, 05:01 AM
Check the Water Filter. Maybe its time for a new one if it hasn't been replaced recently. Wouldn't hurt to check the anode rod in hot water tank while checking the Water Filter. I change out the anode rod and water filter at the beginning of camping season as its cheap insurance against a rotted out hot water tank and debris going thru system.
Never had to run vinegar thru the lines but something you can try as well.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
08-27-2015, 06:24 AM
[QUOTE=TURBS;965943]
TURBS
2011 32bhok Sabre
Haha, doesn't seem logical but it does happen. The cold water supply line has a check valve to prevent hot water from flowing back into the cold water lines. But when there is a large buildup of particles from the anode rod swirling around, one or more can lodge in the check valve and block it open. The particles can then escape and travel through the system. My anode rod was completely gone and the bottom of the water heater was full of particles. They had also traveled to and blocked screens on the toilets (2) and all of the sink faucet diffuser screens. Flushed the system and installed new rod and problem solved. I now replace the anode every season. You can also prevent or slow the problem if you drain the water heater when coach is being stored.
(2
08-27-2015, 10:03 AM
Thanks everyone. Some very good info here. I'll be working on the issue this weekend.
