Old 05-05-2018, 07:25 PM   #1
water pump
I have a 2014 Georgetown and my water pump does not work. Before I tear the bathroom sink apart can anyone verify that this is correct.
Pauline is offline   Reply With Quote
Old 05-05-2018, 07:35 PM   #2
Exactly what happens when your pump doesn't work? Does the pump run? Does it run but not pump water? Does it run and not shut off? these are things we must know.
Old 05-06-2018, 07:32 AM   #3
Water Pump
Hi
Sorry I did not explain right. I just need to know the location of the water pump.
Old 05-06-2018, 07:47 AM   #4
bubbles's Avatar
Not all Georgetown's (GT) are created equal. What model is your GT?
Old 05-06-2018, 08:02 AM   #5
Water Pump
I have a 335DS Model.
Old 05-06-2018, 08:29 AM   #6
if it runs you can locate it by listening. It may be hiding behind a removable panel. I have heard of they under beds, In bathroom cabinets.
Old 05-06-2018, 11:45 AM   #7
Water Pump
We found it. One of the storage compartments outside had a hard paper panel. We unscrewed that and there was the pump. The plastic holder for the filter was broken (probably from water left in it during the winter). Ordered a new part on amazon for $10.00. Should be here in a couple days. So relieved. Thank you everyone who responded.
Old 05-06-2018, 12:10 PM   #8
First thing I did was remove everyone of those 1/8" plastic panels with 4" ring (3" opening). Another bad design to keep you from doing any service yourself and keeping lawyers at bay! FYI, pump is usually very close to the water tank.
I do not have any before pics, but here are some after. A close up of the SOVs I added is in the second allowing me to open and close without going under in the dirt - Simple idiots at the Factory never considered, are too cheap to include, or because I'm sorry some customers don't ever think about what they are doing before they do it and the RV industry is paranoid and hides behind lawyers that tell them to not offer anything beyond simple without requiring some thought.
Name:	Water Tank Compartment.jpg
ID:	170810   Click image for larger version
270S is offline   Reply With Quote
Old 05-06-2018, 12:59 PM   #9
Open the outside door just forward of the big under bed storage bay. Open the white plastic access ports...and there it is!
The black plastic is to try to retain the heat to keep the pump and tank from freezing. Lawyers have nothing to do with it. You may have to remove the black panel (3 screws but the front one us a pain.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-06-2018, 01:52 PM   #10
The black 1/8" plastic layer has little to nothing to do with freeze prevention. The aluminum foil, insulation, heat duct and the insulated door itself does 98% of the work. Besides, I refuse to camp if it is that cold. Others may enjoy it though.
pump, water, water pump
