Old 06-23-2014, 09:29 AM   #11
bend302's Avatar
What I have found is that my pump will run if the city pressure is lower than the pump pressure setting. And, yes the pump pulls from the onboard fresh water tank.
That's why I leave pump off when hooked to city water.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 06-23-2014, 02:03 PM   #12
copsuno's Avatar
For what its worth, I never travel with my water pump on. If you need to flush toilet or wash hands, cut pump on then, when done cut off. You do not need to leave on all the time. The water lines in your unit were pressure tested, with air, at 80 psi, buy an adjustable pressure regulator and set it at 60psi and you will be good to go on city hook up.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
pump, water, water pump
