Old 06-22-2014, 04:17 PM   #1
Water Pump
I have a GT 351DS. I know the water pump needs to be on while driving in order to have running water for toilet and sink. But once connected to city water when parked, do I still need to have it on? I noticed faucets still work but pressure seems low with out the pump on. Any advice greatly appreciated. Thanks.
sithc is offline   Reply With Quote
Old 06-22-2014, 04:28 PM   #2
Dijoeboss's Avatar
I don't use the water pump once I'm hooked to local city water. Not sure why water pressure would be lower, mines usually the opposite.....
Dijoeboss is offline   Reply With Quote
Old 06-22-2014, 04:28 PM   #3
BamaBob's Avatar
No, once you are hooked to city water (make SURE you use a pressure regulator!) you are good to go!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-22-2014, 05:41 PM   #4
Ok. Must just be low pressure at the site. It just dawn on me the water pump is probably use to pump water from the fresh tank as I notice my fresh water level decrease since I've had it on.
Old 06-22-2014, 05:50 PM   #5
Ford Idaho's Avatar
Correct, the pump pulls from the tank and has nothing to do with city hook up.
As for the low pressure, do you run a water filter if so what type?
Old 06-22-2014, 06:51 PM   #6
dcheatwood's Avatar
And do you have a water pressure regulator on your hose at the outside faucet? It will cut your pressure down to protect you from bursted lines from too high pressure.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-23-2014, 12:09 AM   #7
Krazymace's Avatar
Good chance your filter needs to be replaced.
Question - if the pump is on at the same time I'm connected to city water, where does water come from when I open a faucet? The tank or city?
Krazymace is offline   Reply With Quote
Old 06-23-2014, 03:08 AM   #8
Yes I use a water pressure regulator as well as an inline water filter on the hose (those blue plastic tube thing). Come to think of it, the filter is old from last season. That was probably the cause. I'll change it out. Thanks.
Old 06-23-2014, 03:11 AM   #9
Krazymaze... I'm guessing it draws from the fresh water tank. As that is what happen to me this weekend. I could here the pump go on each time I used water. Plus my fresh water level went down by the time I noticed the situation.
Old 06-23-2014, 07:52 AM   #10
dcheatwood's Avatar
Also check the screen in the pressure regulator. It can clog up and restrict flow.
pump, water, water pump
