Old 11-08-2014, 11:18 AM   #1
water pump bypass for winterizing - no suction
Dear Forum Members,
I got it to work last year, having trouble this year. My pump is on, turned the valve to syphon hose but no suction to take on the antifreeze. What am I missing? Thanks in advance for any advice!
Regards,
Ken
AbsolutMac is offline   Reply With Quote
Old 11-08-2014, 11:19 AM   #2
I have a 2012 Georgetown 350xl
Old 11-08-2014, 11:31 AM   #3
Iggy's Avatar
Originally Posted by AbsolutMac View Post
Dear Forum Members,
Regards,
Ken
Do you have any water in the water tank?
Iggy is online now   Reply With Quote
Old 11-08-2014, 11:37 AM   #4
ramair's Avatar
maybe try adding some water in the tank and using the pump, may have to be primed. once it primed it may work. Then switch over and winterize? Just a thought.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 11-08-2014, 11:39 AM   #5
fonzie's Avatar
If you are using tygon tubing going into anti-freeze jug, make sure tubing is straight down and not curling up otherwise it will not prime.
Fonzie
Old 11-08-2014, 04:56 PM   #6
Tim & Lisa Trempert
Dear Forum Members,
Regards,
Ken
You have to open the valve to the antifreeze hose AND close the valve to the fresh water tank. They are both right there very close to each other.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 11-15-2014, 06:30 PM   #7
absolut..............
just winterized my 2010 and was doing the same thing. Just pour some antifreeze into the siphon tube and then shove it into the bottle. It will start to pump fluid right away.
Kurt
kurtm is offline   Reply With Quote
Old 11-15-2014, 06:38 PM   #8
Mr. Dan's Avatar
On mine (I have a different unit), I had to turn on a faucet in the trailer to get the action going. I wouldn't think having water in your FW tank would have anything to do with it. The theory is to pump from the antifreeze bottle rather than the FW tank. (see Trempert's post)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 11-15-2014, 07:10 PM   #9
I had the same problem for about 15 minutes... Forgot to take the cap/plug out of the take up tube.... Once my brain fart cleared, it all worked well.
Jim Sullivan is offline   Reply With Quote
Old 11-20-2014, 07:33 AM   #10
winterizing
Mr. Dan
You have to open a faucet to relieve back pressure in the line when the pump tries to prime. These pumps don't have a lot of power so they need all the help you can give them.
Kurt
bypass, pump, water, water pump, winter, winterize
