12-31-2017, 08:56 PM
Water pumps won’t work after de-winterizing 2017 364TS Georgetown
Left Cincinnati in 5 degree weather. Dealer winterized and advised against de-winterizing until I got farther South. I am around Ft Lauderdale and drained water from water filter by city water fill connection. I turned the 3 valves behind each water heater after I drained all red antifreeze out of all lines by the faucets. I also cycled the washer dryer combo put low drain plug back in but no water comes out of faucets with pump on? It works when connected to city water but not on it’s own pump from freshwater holding tank on board after I filled it. Any ideas? I know I did something wrong but I thought I did what they told me. Thanks for any help.
DK
12-31-2017, 09:14 PM
Did dealer leave the winterizing valve on input side of pump in winterizing position?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
12-31-2017, 09:22 PM
Sorry don’t know what or where that is?
12-31-2017, 09:23 PM
Not sure what that is or where it is locTed thanks for helping on New Years Eve
12-31-2017, 09:24 PM
Don’t know whT that is or where it is ? Sorry
12-31-2017, 09:27 PM
I changed the three valve positions beside the two water heaters. But not sure about the valve you mentioned.
Thanks Again
12-31-2017, 09:47 PM
Not sure what that is or where. Sorry
12-31-2017, 09:50 PM
At your docking station, see if there is a valve that says "winterizing" or something similar. Make sure its turned away from the winterizing setting.
In winterizing mode, it makes the water pump pull from an RV jug or something similar and not the freshwater tank.
That's how it works on our fiver. Maybe the same as your motorhome?
12-31-2017, 09:53 PM
Got it Thanks ! Just one question where is docking station or what is docking station? I do remember him siphoning antifreeze from big bucket with hose and the hose came with the rv it is behind water heaters I believe?
12-31-2017, 09:55 PM
That is the one thing they did not tell me about when I asked for direction on de-winterizing at dealer[emoji1]Thanks Again!!! Would there be more than one? I have two water heaters!
12-31-2017, 09:58 PM
A docking station is usually the place where everything is: your water connections, sometimes it has your black and grey tank valve levers, your cable TV connection, etc.
Hopefully you have one but if he did suck RV antifreeze from a jug, it is extremely likely this winterizing lever is what you're looking for.
12-31-2017, 10:00 PM
If not, look maybe near your freshwater hook-up.
12-31-2017, 10:02 PM
Thanks So Much!!
Have a wonderful New Year!
With your information I am sure I can find it in the am.
Sincerely,
Dennis King
12-31-2017, 10:05 PM
Let us know how it works out.
At least you're in Fl. Its even going to be around 15 tonight here in NC.
12-31-2017, 10:17 PM
Will Do! Hope you get warm weather soon!!![emoji1]
01-01-2018, 07:57 AM
The rectangle bin under the bunk side. Both water pumps and the fresh water tank in there. Each pump has a switch in it. That is how they suck the pink antifreeze into the system. You'll see about 3' of hose coming off each pump with a plug in the end, each pump has it's own switch to suck from that hose to get water or to get it from the plumbed system. Also this may be simple but you did switch the pumps on on both wall panels, one in back bath and the other in main panel by front bath, correct?
2015 Georgetown 364TS, '05 TJ flat, or '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
Days Out '17-25{Days in Shop 141}; '16-59; '15-56.
2011 Flagstaff V-Lite 30WFKS '14-24, '13-33, '12-36, '11-29, '10-23.
01-01-2018, 08:53 AM
Thanks! I will check that in a few minutes. That helps narrow down the area. I will let you know after I try. Thanks
01-01-2018, 10:34 AM
I found the pumps but see no switch on the pumps? I see a white valve off a hose on each and a little glass ball type thing that looks like there is a touch of antifreeze in it. Could that be it? Hope it does not hurt water heater being it looks like there is a little antifreeze. Should I turn all 3 water heater valves again to keep it out before I turn those valves. Again thanks so much everyone for your help on New Year’s day. I have attached two or three photos hopefully?
01-01-2018, 01:20 PM
Weekender
Those valves that are shown in the pump discharge may need to be changed. Can't tell from the photo where they go, but I would switch them to the other position.
01-01-2018, 01:28 PM
The clear things you see are sediment filters to keep junk out of the pump.
