Checking out the 391 for our weekend trip I looked at the water tank with the access panel completely removed. Despite opening all the drain lines about an inch or so of water remains in the tank. The drain line enters the tank too high to allow a path for those last gallons. I think I see why FR does it so they don't weaken the tank.
Any ideas about getting the last drops out. If my rig sits idle long enough, the water is going to get pretty funky.
Tilt the camper towards where the drain line comes out. After that, drive it around a bit with the drain line open. That should pretty much get rid of most of the water.
There are fittings available that can be installed into your water tank. You drill a hole into the tank and these fittings are designed to be installed without inside access. I used one quite successfully in my last TT (a Roo 26RS). I hung a much larger water tank to the bottom of the trailer and needed to change the location of the outlet to suit my needs. I found the fitting at a local RV dealer as a stock item.
You could use one of these fittings to either create a new low point drain or a new outlet to better utilize the water in the tank.
I'm going to get a quote on replacing the carpeting with some sort of wood or wood-like flooring. Three dogs and a carpet don't mix.
Not to hijack your thread, but there are several good thread on RV discussing self installation of Allure flooring bought at Home Depot. Have not tried it myself, but it may be an option in a few years.
2010 373DS
Master Tow with 2008 Nissan Altima
Hijack away. Before I spend thousands, I'll ask for and listen to advice. I went to the RV.net site but all my queries for allure or flooring failed. Can you give me a specific thread.
Thanks.
p.s. If anyone else is thinking about flooring or has done it, I'll start a whole new thread.
Thanks.
I met a superviser at Camping World today and he estimated about $13K to install new wood or wood like flooring. It was $1,500 per slide to remove and install to do the work.
I went to an RV body shop that does extensive stuff and they came back with about $10,000 plus materials to do the job. Ouch!
