Old 01-29-2015, 10:03 AM   #1
water tank drain valve location
I cannot locate the drain valve on my 1999 Georgetown 325s. I am new to this rv and cannot seem to find this info anywhere in manuals. THANKS
fbeechhill is offline   Reply With Quote
Old 01-29-2015, 10:14 AM   #2
bubbles's Avatar
May not be a valve, just a waterline with a cap or plug installed. Sticking out the bottom of the unit.
Old 01-29-2015, 11:18 AM   #3
Krazymace's Avatar
I had to crawl around under my coach. Found 2 white hoses with caps right behind the rear wheel mudflap on passenger side. Not very convenient.
Krazymace is offline   Reply With Quote
Old 01-29-2015, 12:17 PM   #4
Iggy's Avatar
May look like this.
One is your water tank drain.
One is the water tank overflow
And not sure what the 3rd one is for.
Name:	Mod Picture 042.jpg
ID:	68981   Click image for larger version
Name:	Mod Picture 043.jpg
Old 01-29-2015, 10:16 PM   #5
ramair's Avatar
The 3rd one is the drain for the water lines inside the MH. Way to check is turn off city water and open the plugs (no water in fresh water tank) then turn on city water and you will have a good flow then mark that one. Just helps in referencing in future.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 01-30-2015, 05:00 AM   #6
cjd10's Avatar
On my 1998 325 there were two lines, one red and one white sticking down near the water fill area. No valves just caps on them.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 01-30-2015, 08:00 AM   #7
bubbles's Avatar
Originally Posted by Iggy View Post
May look like this.
Surprised to hear that. It is the low point drain. Some units have both hot and cold water low point drains. Only one is needed on your coach for both hot and cold because the winterization valves, when set to winterize the coach, tie the hot & cold together (one system = one drain).
Old 01-30-2015, 05:44 PM   #8
water drain 325S
This drain is under the bed,there is a valve under there that needs to be turned..it is very slow..To drain your water lines just go to the outside shower and open that up.be sure to pop the water heater relief valve to let that water out...I had one of these for many years,,..You said you are a new owner of this machine..It may be the one I traded in . Did u get it in Texas down around Dallas?
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
cat, drain, location, tank, water, water tank
