Old 09-05-2016, 09:28 PM   #1
Question weatherguru1
MY engine AC is failing again. I have a 2015 Georgetown 352 XL with a Ford V-10. It failed early this summer. It was fixed by a local Ford dealer who said it was only "LOW" on Freon. No leaks or damage of any kind were found. The same thing is happening again. I can only get cool air out, about 70 degrees, when the outside temp is 80 degrees and 45% humidity. Unacceptable by any standard. Can anyone one lead me in the proper direction to get this fixed once and for all?
weatherguru1 is offline   Reply With Quote
Old 09-05-2016, 09:47 PM   #2
asquared's Avatar
On my chevy silverado, I had a similar issue that turned out to be a bad temp sensor. They had to go through replacing the ecm, all wiring and some other part before figuring it out.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-06-2016, 01:53 PM   #3
RVnut's Avatar
sounds like you have a freon leak if it worked ok after they added freon for a while
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 09-09-2016, 08:46 PM   #4
JimF's Avatar
Had our ac compressor replaced, the compressor was leaking between the casing halfs. Sound like ford wants to just charge it instead of finding the real problem. Heard that the compressor leaking is a know issue. Good luck.
JimF
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
JimF is online now   Reply With Quote
Old 09-09-2016, 11:10 PM   #5
abjb's Avatar
First thing you need to do is get a new "dealer"! These compressors are KNOWN to fail...often.
Then get one of these, it has a gauge.
https://www.walmart.com/ip/Deluxe-R-...Gauge/16888796
and a couple of these.
https://www.walmart.com/ip/Speed-Ste...12-oz/20440563
Watch your gauge and don't over fill.
Here's a forum search for R134a (Georgetown only)
http://www.forestriverforums.com/for...archid=6120913
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 09-10-2016, 04:52 AM   #6
If it is low it has a leak.
2016 Georgetown 328ts
2015 Fiat 500 Toad
db7512 is offline   Reply With Quote
