Old 05-22-2014, 08:08 AM   #21
Lostdog, thanks for the reply! Good idea on the fan. I think I'll go to WalMart and pick one up before we head out for the weekend. Are you thinking of replacing the detector? Seeing that your rig is also a 2011, I would assume we have the same model/manfac. of the LP detector.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 05-22-2014, 09:32 AM   #22
Thought about replacing the detector but have you priced them? Way over a hundred bucks with the companion gas valve. It seems the detector that we have has an outdated valve and a new detector requires the new valve. Planned that way, maybe?
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 05-22-2014, 01:08 PM   #23
Evereddie's Avatar
I know nothing about these units. What gas valve? Can your unit turn off the gas if it detects leakage? Don't think mine is wired like that but I guess I should look into it. (Rockwood 2306)
Evereddie is offline   Reply With Quote
Old 05-22-2014, 01:31 PM   #24
VinceU's Avatar
Both of the guys are in Class A m/h which have a ANSI tank fixed to the chassis. It must be fitted with an auto shut down when detector senses a leak in the cabin.
Old 05-22-2014, 01:35 PM   #25
Evereddie's Avatar
OK, got it. Thanks. Figured it was something like that.
Old 05-22-2014, 03:02 PM   #26
Newellri's Avatar
I also have had the co2 unit go off, mine it is the battery's gassing off. Good luck!
Newellri is offline   Reply With Quote
Old 05-22-2014, 03:11 PM   #27
dcheatwood's Avatar
Mine went off when wife busted a jar of pickles. And again while repairing PVC pipe under drain with PVC glue. Apparently they detect any strong smell.
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 05-22-2014, 03:18 PM   #28
It does turn off the gas when it goes off. Look in your propane area and you will see a valve on the gas line that will have wires to it. If your battery switch is on then the valve will be really warm.
Lostdog
Old 05-22-2014, 03:21 PM   #29
Newellri's Avatar
What is the cost of a complete new unit, they have a life span of app 5 years!
Old 05-22-2014, 04:02 PM   #30
Timex's Avatar
May have to replace mine
Mine has been screaming off/on for a few days. I have the TT plugged into the AC in the shed. No gas is turned on, nothing going on inside or out. Thought I'd check the battery on the tongue. Turned the power off, put a meter on the +/- terminals and it read 11.38. I figure the battery is dead or dying. So, I'll probably replace it with a deep cycle battery soon. The durn thing came brand new with a car battery! Didn't know any better until I started reading up on FRF that I had the wrong battery! Guess I got snookered by the dealer on that one.
Well, I pulled the alarm away from the wall and saw that it had a Rapunzel bunch of wires connected to the red/black wires of the alarm. Of course, if I were to replace the alarm, I'd hook it back the way it is now, with a big wire nut. But, can anybody say what/where all the other wires go to?
Timex is offline   Reply With Quote
