Old 10-30-2012, 07:12 PM   #11
Freds342's Avatar
Originally Posted by SpringerPop View Post
It sounds to me as if the speed sensor in the rear differential is intermittent. It is the typical Hall-effect device, and if it is not sending pulses to the Powertrain Control Module (PCM) you will have no speedometer, not cruise control, no ABS, and likely have erratic shifting points.
If that's the case, check that wiring to that sensor. It's located somewhere in the upper half of the differential housing.
If you wish to remove it, there's one bolt that holds it in place, and if you remove it, no oil will escape. Just be careful to clean around it first so dirt doesn't drop in the hole when you remove the sensor. You may find a bit of black, fuzzy, sooty material that has collected on it (it's magnetic), and sometimes just cleaning it is enough to restore operation. It's sealed with an O-ring, so be careful not to damage that when re-installing the sensor.
If you actually need a new one, they're relatively cheap at around $25 or so, but you may find a broken wire, too, and that may fix the whole thing.
Good luck!
Pop
X2; common Ford Problem.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 11-01-2012, 08:16 AM   #12
OK took the sensor out clean it put back in(man it was dirty). Couldn't find the plug to read code that was on service engine soon so removed battery cables light went out.
Where is that plug located on the m/h to plug reader in?
trell is offline   Reply With Quote
Old 11-01-2012, 09:23 AM   #13
VinceU's Avatar
Under dash at knee level with attached cap. Size 3/4" height x 1.5" width ( approx )
Old 11-01-2012, 04:32 PM   #14
VinceU's Avatar
Heres a pic of it at center console 12" above floor.
Old 11-01-2012, 04:43 PM   #15
Another rat in the race
jar3316's Avatar
If it comes back check the ECM connectors, the CC module, and the cluster connector one of them could have been knocked loose. Depending on your service they might have plugged directly into your harness at the ECM to check wiring and the ECM.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
Old 11-01-2012, 05:07 PM   #16
dfskinner's Avatar
Advanced Auto & Autozone will both read the codes for you; go there before you ever go to the dealer or anyone..... knowing these codes will help you be a smarter consumer.....
dfskinner is offline   Reply With Quote
Old 11-01-2012, 05:21 PM   #17
Would that plug have a cap on it that says "Data link connector''?
Old 11-01-2012, 06:19 PM   #18
Too old to be too smart
SpringerPop's Avatar
Yup, although some have blank caps, some have no caps at all.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 11-02-2012, 08:09 AM   #19
A big Thank You to all of you. I sure do like this forum.
Old 11-17-2012, 09:55 PM   #20
did you get it fixed?
genesimmons is offline   Reply With Quote
