Old 09-19-2015, 11:21 PM   #11
Originally Posted by camaraderie View Post
Ditto wrapperman...remove cabinet and follow power cord route..
Fuse will be right there. Happens a lot.
Power fuse inside microwave. remove cover and replace. ace hardware or electrical supply store has fuses rated for microwave. make sure you replace fuse with same size and rating.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 09-26-2015, 10:07 AM   #12
siskom's Avatar
microwave
I have repaired a few of them in the past.. like mentioned above pull microwave check fuse first if blown replace and start up microwave if it sounds different then it has all along making different noise when heating the magnetron is probably going which drew to much current blowing the fuse. make sure if you replace fuse get a slow blow fuse same size.
siskom is offline   Reply With Quote
Old 09-26-2015, 10:14 AM   #13
Ford Idaho's Avatar
Originally Posted by Lostdog View Post
Going on 5 years old...
The good die young!
Old 09-26-2015, 02:27 PM   #14
Thanks for all the input folks. Found that the magnetron had crapped out and blew the internal fuse. Had to buy another and just got done with the install. At 70 plus pounds it took two of us "grown" men to remove and replace but the DW is happy to be able to bake again!
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
