Old 05-08-2011, 10:09 PM   #1
Wet Awning
On our maiden voyage we pulled the awning out and was surprised to find water dripping off of it. We sort of thought that maybe it had been washed at the dealer & rolled up wet. It was dry when we rolled it up but today I wanted to check it, so we pulled it out and it was WET on both sides. Water rolled off as we opened it and dripped from the underside once it was out.
We never had water collect in/on the awning of the Trail Lite so assumed this one should be dry as well but it was wet from the outside edge all the way to where it's attached to the roof.
Is this normal?
If not, can anyone guess what might be the problem and how to fix it?
Karen
Enjoying the great outdoors with one hubby and 2 boxers!
2011 Georgetown 280DS
2010 Jeep Wangler 4x4 Toad
KarenS144 is offline   Reply With Quote
Old 05-09-2011, 05:46 AM   #2
Wet Awning
We are experiencing the exact same thing on our Rockwood. I have no clue why or if there is a fix. The only thing I know to do is unroll it every couple weeks and dry it out to avoid mildew.
Just thought I'd let you know you're not alone, hopefully someone else will have answers. Also, since yours is new, maybe your dealer will help.
2007 Rockwood Signature Ultra Lite 8280SS
2011 Silverado 2500HD/ Duramax 6.6/ Allison
smilin joe is offline   Reply With Quote
Old 05-09-2011, 05:54 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
Is this normal?
Our awning gets wet any time it rains when rolled up. I open it every once in a while to dry it out. I believe the water runs in at the metal covering and ends up on the top of the material. Since the awning rolls out from under in a clockwise direction the water ends up on both top and bottom of the fabric. I don't know of any fix for this, it's just the way it's designed.
If you should have frost in your area and leave the wind sensor turned on the box will start beeping. Found this out at 1:30 AM a couple years ago when my daughter came home from work. It was about 2 degrees out that night and the box was chirping non-stop.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 05-09-2011, 06:06 AM   #4
Herk7769's Avatar
Times X for our power awning.
I have to unroll it after every rain to let it dry out too.
HAM CALLSIGN - KC3FFW
Old 05-09-2011, 06:29 AM   #5
The Trail Lite must have had a waterproof section at the top so when it rolled up, that strip covered the awning. We're going to build a garage for the MH so that will eliminate the problem but it is going to be a PITA to have to worry about drying the awning after every rain until then.
It would seem that the awning fabric would have to leak in order to get the entire roll wet. Do the awnings leak in the rain when open?
Karen
Old 05-09-2011, 06:44 AM   #6
Herk7769's Avatar
I was looking at the roller the other day and a slot is facing out. I think the rain runs down the slot and into the roll. (best guess)
Old 05-09-2011, 06:45 AM   #7
KyDan's Avatar
Mine does it too. I think the water wicks in from the ends
rather than soaking thru the vinyl coated fabric.
I also think the awning drum adds to this.
There are grooves in the drum which make perfect little
channels for water to run in from the ends.
I think a smooth drum would be a better design!
We open ours every time we go camping whether
we need it or not just to let it dry out.
Mildew is a constant worry but so far we've only had a few
small incidences of it.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 05-09-2011, 11:08 AM   #8
I don't think my 2011 360 has a wind or rain sensor...would anyone know ???
polkatronron is offline   Reply With Quote
Old 05-09-2011, 11:30 AM   #9
Add me to the club, as well. I have looked at ways to fix it, but so far, ZIP.
Old 05-09-2011, 11:38 AM   #10
Villa Estate 392FLFB
The_Stuff's Avatar
and yet i unrolled mine the other day after the snow melted and it was dry as a bone... maybe its the tension not being enough?
One state/province at a time!
The_Stuff is offline   Reply With Quote
awning
