11-03-2017, 05:02 PM
Wet parking
Well Kentucky deer season is here next week, suppose to rain 4 of 9 days before we arrive. Our normal boondocking parking is in a field on top of hill, flat area to pull off road and is mainly hardpack and have not had issues in the past. I am trying to figure out how do I know if the field is hard enough to pull in. I surely do not want to sink my 329 in the field. Nearest camp ground is 30 miles, and hampers hunting traveling back and forth.
Any ideas, I am pretty sure the responses are, don't chance it
11-03-2017, 05:08 PM
Location: Alberta - East of the Rockies, West of the Rest
To be honest, and I don't mean to be rude, let someone else try it out before you go. Once the trailer starts to go down you won't be able to back out, getting stuck with an rv is no laughing matter, trust me.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
11-03-2017, 05:09 PM
Well the way I used to test for a 26000lb plus drill rig was walk in on my heals and if I sank in it was normal too wet and soft
11-03-2017, 05:15 PM
Great advice!
2016 Salem 27RKSS
11-03-2017, 05:30 PM
X2--> I got stuck on my first trip out and once the trailer starts sinking your gonna have trouble. Just keep your wits about you if this occurs and don't do anything that will make your situation worse. Remember that you have leveling boards with you (I hope) and if an issue occurs you can use them for dry ramps. Disconnecting the truck and trailer, pulling forward, placing the leveling boards under where the wheels will be, then backing onto the boards, and reconnecting the camper worked really well. Next time though if I question the area to drive/park I'll disconnect and go in the area without the load first. I've also added a tow strap to my supplies cause ya just never know.
My getting stuck was a long story but basically I was stuck twice within 20 minutes. Ironically and fortunately I felt the truck sinking first and headed for harder ground before the truck wheels started to spin. Notice that I said harder ground not solid ground.
To make this even worse I also experienced the shackles flipping during this same trip when the wheels were both lifted off the sloped ground that happened to be the only dry enough area to park.
2018 Cedar Creek Silverback 29IK
18 Silverado 3500 HD Dually 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
11-03-2017, 06:42 PM
Tow straps are good to have. However, snatch straps are probably better & safer for pulling stuck vehicles.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
11-03-2017, 06:52 PM
I am a coward when it comes to towing. When in doubt, I don't. Pretty simple rule.
Once committed, go for it and hope it works. Not as good as the above.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
11-03-2017, 07:23 PM
Scoundrel
If you see a few deer laying around having a couple beers nearby where you park, don't go in there.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
