Old 09-27-2016, 08:33 PM   #1
BillMFl's Avatar
WFCO 3 stage 65 amp convertor/charger
Any opinions about this unit? My parallax convertor smells like it is overheating even though the fan works. The parallax is a two stage. The WFCO three stage should be better for the house batteries not overcharging or boiling off. Anybody have experience with WFCO?
BillMFl is offline   Reply With Quote
Old 09-27-2016, 09:08 PM   #2
Citrus County, Fl.
GL1800Rider's Avatar
WFCO does not have a very good reputation. I would suggest a Progressive Dynamics. They are 4 stage units. I am not sure if they have a 65 amp but do know they have a 60 and also a 90. Best Converter is a good family owned business to deal with.
Another good brand that they carry is the Boondocker
Progressive Dynamics Converters
2016 Forester 3011DS
2015 Toyota Corrola S toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 09-27-2016, 09:20 PM   #3
X2 on PD.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 09-27-2016, 09:39 PM   #4
Iggy's Avatar
X3
This is what was installed in my 2012 Georgetown. (70 amp version)
Your different?
Name:	Trailer Pics 010.jpg
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Old 09-27-2016, 10:33 PM   #5
HONDAMAN174's Avatar
I removed my working WFCO for a 55 amp PD in my TT. Big difference! Happy I made the change.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 09-27-2016, 10:49 PM   #6
Bluepill's Avatar
Not happy with my factory-installed WFCO. It has never switched into Bulk Charge mode, so I have to finish my charging with a stand-alone battery charger. Many other reports of this problem.
2008 Itasca Meridian 37H
Old 09-27-2016, 11:09 PM   #7
WFCO Converter
We just purchased a used TT with this converter. Our 12v lights and A/C will intermittently flash on and off. The fan seems to run constantly until I turn the lights off with the switch. We did check battery which as a couple dead cells. Battery definitely needs replaced but in order to eliminate causes we ran a jumper cable from the truck to the battery but the lights still flash on and off. A/C didn't seem to have a problem though. Any suggestions what might be causing the problem?
CamFam is offline   Reply With Quote
Old 09-28-2016, 10:47 AM   #8
waiter21's Avatar
I replaced my single stage for a 4 stage in my Mirada.
What I would do different, I cut the old unit out and installed the new unit in the same cabinet. If was doing this again today, I'd leave the old unit installed, just disconnect it, and connect in the new unit. That way if I ever sell the MH, I can remove the new 4 stage unit and use it in my next MH (if needed)
Dometic Awning Fabric Protection Door Roller Kit - Accessories - Entry Door - Hardware
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 09-28-2016, 07:28 PM   #9
camaraderie's Avatar
Suggest IOTA DLS75/IQ4 IOTA Product Specifications see also IQ4 link.
https://www.amazon.com/DLS-75-AUTOMA.../dp/B0074JVO8C
or Progressive Dynamics PD9270 PD9270 70 Amp RV Power Converter Charger
https://www.amazon.com/Progressive-D.../dp/B0039T059U
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 09-28-2016, 07:37 PM   #10
Mr. Dan's Avatar
Did you intend to post a link to an awning fabric protector/roller?
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 00; booked = 14
wfco
