Originally Posted by BillMFl
There is a flexible tube that screws onto the oil quart and lets you pour the oil way easier and without spilling. It even has a shut off valve. Don't remember the cost but think it was less than $5 at Wallyworld. At first I had my oil changers done at a Ford truck dealer but I discovered in year two that they never greased the number 9 fitting that hides under a plastic cap near the stearing box. The other factor that contributed to doing my own service was not the cost. It was having to drive to/from and wait at the service center. It was just more convenient to do it myself. Got all the tools and worked as a mechanic as a young man. But that fill tube is a pain if you don't have a flexible fill device. Miss the days when all you needed was a timing light and dwell tachometer to do your own tunes.
Thanks! I just KNEW there had to be something like that flexible cap you describe out there SOMEWHERE
And yes exactly right on the inconvenience factor!
Only one of the 4 or 5 Ford dealerships in Cincinnati area will service an RV. Fuller Ford is a great dealership but they are near downtown area off I-75 (always under construction) and my RV is stored 35 miles away -- setting up and getting the G-town in for an oil change on the appointed day and then getting it back to its parking pad in Batavia, OH is a real HASSLE -- it is an all day affair.
I do plan to grease the steering also while I am waiting for the oil to drain out.
As to simpler days -- YES! Working on motors was fun because I knew exactly what I was doing -- it became much less like fun starting about 1980 or so..............
