Old 05-13-2016, 02:27 PM   #11
For my dual axle trailers, I use PT 2x8s cut to 4', 5', 6' & 7'. That will give up to 6" of lift to level the trailer. I stagger them as I stack them so they are easier to drive the trailer wheels up them. I use a 4' level to determine how many boards I will need. (Place the level on the floor and double the distance it takes to show level. Example; if you have to lift on end 3/4" to show level, place one board under the wheels on that side of the trailer to level the trailer.) In rainy weather or if I am on soft ground, I will place an extra board under both sets of wheels to prevent them from sinking into the ground.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 05-13-2016, 02:44 PM   #12
mkekflyers's Avatar
Leveling Tools
Just ran out to Menards because they have a "left over" lumber spot in the lumber area. Picked up some 2 X 10 X 36" - just what was there for a whole $1.69 ea. Cut them into 10" sections. Picked up some 3/8" nylon cord from local Harbor Freight for a buck. Cut the cord about a foot long, stapled it on the flat surface of one 2 X 10 X 10, put another 2 X 10 X 10 on top & put 4 drywall screws in square pattern...walla...pads for under the jack pads. Nylon is a loop on one side, works like a handle...easy, cheap, replace anytime they get messed up...
2018 Georgetown 378 XL
2012 Ford Edge TOAD
Blue Ox & RVIBrake
2014 - 37; 2015 - 58; 2016 - 64;
2017 - 93, 2018 - 101
mkekflyers is online now   Reply With Quote
Old 05-13-2016, 02:45 PM   #13
RETIRED
n-e-d's Avatar
I generally level the coach with Camco tri level ramps,rated at 3500#. Ialso carry 2x10s and plywood if needed
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is offline   Reply With Quote
Old 05-13-2016, 05:07 PM   #14
Mine is easy. Single axle pup. A ball leveler is all I need. I have seen several class A with a front wheel way off the ground. Looks scary.
Dodaman is offline   Reply With Quote
Old 05-13-2016, 05:15 PM   #15
Originally Posted by Stevekaz99 View Post
Do you use one for each axle on the 5er?
Yes we did and it worked great, but as said you need two people to do it.
Person two puts the levelers in front of the wheels, holds the level on the side of the 5er as the driver inches forward. Hand signals tell the driver when to stop, then person two places the chocks behind the levelers CAREFULLY.
Let off the brake, double check the level and if it does not settle back down too far you are done. If not inch forward again and shove the chocks in harder, sometimes with a rubber hammer.
Sandy and Shirley is offline   Reply With Quote
Old 05-13-2016, 08:11 PM   #16
Hi,
That's a great question, and maybe this a good place for me to inject a leveling problem I had with my TT at a local state Park: The site was nicely level left to right, but not front to back. No matter where I put the trailer, the hitch jack was almost fully extended - even with two 4x4s and a 2x8 base. There seemed to be no option but to accept things as they were, so my wife and I cautiously moved around inside, hoping the wheel chocks would hold. Not a comfortable stay...
The park is beautiful, but I don't think we'll be staying there again because it looks like most sites are sloped front to back.
I was thinking next time maybe we could try a couple of scissor jacks on the front of the frame instead of putting the whole load on that single point. Trouble is, we'd still have to bring the jacks up to the frame.
Anyone out there have another suggestion? (Thanks)
twenty4pack is offline   Reply With Quote
Old 05-13-2016, 08:26 PM   #17
northstar1960's Avatar
I use the andersen leverlers also being a one man show i've never had problem setting them up .since i double stick taped a nice little bubble level on the front of my TH i can see it when pulling fwd . no need for two people to do it . holding a level on the unit and pulling it fwd seems awkward to say the least . have never needed more then the 4" they provide but if i ever do then i've got 2-2x6x6' that give me another 3" but never needed them
northstar1960 is offline   Reply With Quote
Old 05-13-2016, 08:45 PM   #18
chrisbailey13's Avatar
We all get into campsites that are not level.
Some sites are so out of level that using the jacks alone would raise the tires off the ground, a very bad thing to do!
Our Georgetown is rated at 24,000 lbs., sitting on 6 tires, is an average of 4,000 lbs. per tire.
There are 4 jacks which is an average of 6,000 lbs. per jack.
The best “standard” leveling blocks we could find were the Camco 44505’s which are rated at only 3,000 lbs. per block and they cost about $3 per block on sale.
The only “special” ones we found are called “Utility Blocks” but it looks like they cost about $20 each on Amazon, but they do not interlock as well and do not have optional wheel chocks or special top plates to make a flat surface for the tires..
What does everyone use for leveling?
When you say tires are raised off the ground are you referring to the front or rear tires.
I have been at sites that required the front tires to come off the ground in our Georgetown and haven't had any problems with stability. I typically will try to manually level the RV by raising the front first and only lowering the rear levels so they touch the ground for "stability" only.
Usually when the front wheels come off the ground it is because the auto leveler lowers the rear stabilizers first which causes the fronts to raise.
I have also been in sites where the rear was lower than the front. in those cases, again, I manually level, but I also put wheel chocks under the front tires to help keep the coach from rolling backward because I have taken SOME of the weight off the rear wheels and the park brake. BUT I am careful not to let the REAR wheels to ever leave the ground when leveling.
Finally, I have also seen people use these to help support the wheels when the angle is too steep.
One final thought (Feel free to dispute) Our level systems in Georgtowns will tell you when the angle of the site is too steep for the levels to support the coach, that along whit a little creativity should take some of the worry out of leveling the MH.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 05-14-2016, 10:06 AM   #19
RVnut's Avatar
we always keep the rear tires on the ground but dont worry about the front as long as it levels out..We just make sure the emergency brake will keep the MH from shifting.. Once the jacks start raising the front the wheels are doing nothing to support the vehicle anyway..
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 05-14-2016, 11:42 AM   #20
This question is for NDCamperdude. The Horse stall mats is a great idea I have them under my deck (from Tractor Supply) and with the enclosed deck they are great. Question I have not tried to cut them. What did you use to cut them Circular saw or what?
Wayne
Wayne and Gayle Wilson
2016 F-150 3.5 Eco Boost Max Tow Package
2014 Flagstaff Classic Super Lite 8528RKWS
wfwilson is offline   Reply With Quote
leveling
