Old 08-17-2016, 07:07 PM   #1
RVnut's Avatar
What is this for??
I have this little dome on the roof just behind the radio antenna and only about two feet behind the front cap.. Cant figure out what it is for.. Excuse the finger
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 08-17-2016, 07:08 PM   #2
swamprat26's Avatar
I have 2 like that and wonder the same
swamprat26 is offline   Reply With Quote
Old 08-17-2016, 07:11 PM   #3
Usually a skylight. You dont have one?
donniedu is online now   Reply With Quote
Old 08-17-2016, 07:16 PM   #4
RVnut's Avatar
That is right above the front bunk and there is no hole in the ceiling an it is maybe 6" across
364 Georgetown 2016
in Montana
Old 08-17-2016, 07:38 PM   #5
I was going to guess for a dome satellite? But then read Swamprat wrote he has two! Two dome satellite locations ?
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 08-17-2016, 07:43 PM   #6
swamprat26's Avatar
I have 2 and they above my front cabinets. No skylight. I was thinking some kind of access.
Old 08-18-2016, 01:43 PM   #7
BGinVA's Avatar
Send a message via AIM to BGinVA
I would guess it is for the Sirius XM radio antenna. If you have a second one, that might be for an integrated GPS antenna. FYI, third party manufacturers have started manufacturing a rooftop antenna for Sirius XM that looks a lot like the small dome, but RV manufacturers may not be using that yet due to much higher cost. The traditional XM antenna is a small (~ 1" x 1") cube that might not withstand the abuse a roof can get under normal conditions without the domed cover.
BGinVA is online now   Reply With Quote
Old 08-18-2016, 01:46 PM   #8
swamprat26's Avatar
Very possible. I have GPS and Sirius
Old 08-18-2016, 02:09 PM   #9
RVnut's Avatar
Ok just contacted our factory rep and he says it is where the factory prewires the AC unit before install
364 Georgetown 2016
in Montana
Old 08-18-2016, 02:35 PM   #10
Most prewires goes to a roof vent??
Bob Vaughn is offline   Reply With Quote
