Old 04-16-2011, 08:17 PM   #1
Wheel lug covers
I have a 2010 Georgetown on a Ford chassis. On my last trip one of those little chrome wheel lug nut covers came off or someone thought they needed it worse than me. In any event I need to find a replacement. Can someone tell me where I can buy these little chromed covers? Are they something supplied by Ford with the chassis or are these some sort of aftermarket item put on by Forest River when applying the rest of the icing?
Lloyd
starburst2 is offline   Reply With Quote
Old 04-16-2011, 09:23 PM   #2
M109Rrider's Avatar
I've seen stuff like that at truck stops and big truck parts places.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 04-16-2011, 09:32 PM   #3
Yep you can get them at truck supply places or truck stops...I keep a couple of spares
polkatronron is offline   Reply With Quote
Old 04-16-2011, 10:25 PM   #4
Thanks for the info
Lloyd
Old 04-23-2011, 06:32 PM   #5
can someone tell me how to remove the lug covers so i can get at the lug nut?
rogann is offline   Reply With Quote
Old 04-23-2011, 06:49 PM   #6
Los Popes's Avatar
Your rig should have come with a tool to the remove the cover. Looks like a t-bar handled not so sturdy lug wrench. Three of the lug nuts on the chrome cover hold it on and are marked with dashed indentations. They are easy to remove and viola the cover comes off.
Bubba & Chiquita + Two Vizslas (Barley and Sophie)
2008 Georgetown 315DS SE LTD
2011 Jeep Wrangler Unlimited Rubicon
Sterling All-Terrain Tow Bar - SMI Stay-In-Play Duo
Do What You Like - Like What You Do!
Los Popes is offline   Reply With Quote
Old 04-23-2011, 09:18 PM   #7
If they are metal and they push off and on go to a truck stop, they sell a remover that looks like a pair of pliars that is made for them. You can also use that tool to kind of 'squeeze' the cap to a point it goes on tighter.
Jack
PS...here is one off ebay;
HEAVY DUTY LUG NUT PULLER TOOL | eBay
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
Old 04-23-2011, 09:49 PM   #8
lug nuts
i managed to get one off with a pipe wrench the others were torqued so tightly they were unmoveable
Old 05-01-2011, 01:46 PM   #9
Starburst2 - Here is what I did. I lost (or someone permanently borrowed) one of my lug nut covers and the nut inside on my 2011 Georgetown 350. You can find the chrome covers at truckstops but you will struggle to fine the jam nut that fits inside of the cover and then fits a 22mm stud, assuming the nut inside is also missing.
The covers are made by a company called Kaper II, Inc. I called them and ordered three of the cover/jam nut combinations for $30 which included shipping (figured I might as well have a couple of spares).
Here is their contact info and the item number (took us a while to figure out the item number but these are the correct ones for the 2011 georgetown 350)
Kaper II
2212 Parrott Way
Leso, WA 98626
360-423-4404
email: info@kaper2.com
Item # L-225
Description: Cover, Lug nut / Jam Nut Combo, for a A-225k, fits 22mm Stud
Hope this helps,
Brian
blightle is offline   Reply With Quote
