12-05-2015, 06:23 PM
Kanadian Kamper
When did you replace your Georgetown tires?
Just wondering if GT owners are replacing their tires based on age of the tires or the mileage.
If replacing due to mileage.........what mileage did you get?
Maybe it's time to ask Santa
Ken and Terry
12-05-2015, 06:55 PM
Earlier this year I bought a 2008 Georgetown with original tires. Replaced before first trip. Seven years is my max for tire age regardless of mileage or condition.
12-05-2015, 09:36 PM
Just bought 2011 GT 360xl 78000km (49000m) . Rear michelin xrv are 40% worn out, front are 60% worn and not evenly wornout. I will replace the front one. I am going south from Toronto. I might drive in slippery condition. That is why I change the front.
12-05-2015, 11:46 PM
I would be looking at and alignment also.
George & Jerri
06 GT 340 TSSE
USMC
12-06-2015, 09:32 AM
For sure I will. It is on the working order.
12-06-2015, 02:46 PM
Age is the most important as we rarely wear tires out first. Obviously if tread is gone then replace, but 7 years is the most I would go regardless of wear. After all, there's a lot riding on them.
12-06-2015, 03:50 PM
2003 Georgetown 325
Yes, age is the thing and between 6 and 7 years is ideal. Anything over that and you are riding on a potential bomb that will tear your rig apart.
12-06-2015, 04:08 PM
GEEEEEEEEZE!!! The sky is falling, the sky is falling. Couldn't resist.
12-06-2015, 04:39 PM
May want to consider changing at 5 years on original tires. They are typically low budget.
12-06-2015, 05:26 PM
Toyo states 10 year casing life.
George & Jerri
06 GT 340 TSSE
USMC
12-06-2015, 06:47 PM
Why not put the new one's on the back.
12-06-2015, 07:37 PM
2011 337 Georgetown on 2010 chassis with 2009 tires.14500 miles. One on the front blew out the sidewall so I changed the 2 fronts. Will change out the rears this winter. No more Goodyear junk for me.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
12-06-2015, 09:27 PM
On my 2012 I have 42,000 miles.
No flats, no blow out.! Knock on wood and they only show some wear.
Here is a picture of on set of my rear tires
12-06-2015, 11:21 PM
If I put the new tires at the rear It will be 6/32" less rubber with dual each side??? I prefer let the rear work equally.
12-07-2015, 08:44 AM
My 2011 GT has 69000 miles on the rear tires and 51k on the fronts. I figure another 30k until all need replacing. The fronts have less mileage because FR replaced them at 18k due to uneven wear caused by a very very badly misaligned front end. As delivered, the front end had over 0.80" toe in, way over the 0.1" maximum in the specifications. At 18K, my right front tire had a palm sized patch where I was running on the cords. Another hundred miles or so and I would have had a blowout.
Phil
12-07-2015, 08:46 AM
I replaced the tires on my 2003 F-15 a couple of years ago,,, they only had about 32,000 on them,,, but they were 10 years old,,, still had pretty good tread !!!
10 years is probably pushing it !!!
12-07-2015, 09:03 AM
This month's Motor Home magazine has an in-depth article on tire replacement. I had always heard 7 years max. The article says with good care they should be inspected by a professional in 7 years but a good tire like Michelin may go 10 if stored out of the sun and harsh weather.
12-07-2015, 09:23 AM
Sounds about right to me,,, my F-150 has always been stored in the garage !!!
12-07-2015, 11:52 AM
I will say with our last motorhome we started blowing tires right at the 7 year mark so we will never go past that.. Its not worth it even though they still had plenty of tread
364 Georgetown 2016
in Montana
12-07-2015, 12:08 PM
I read mogman they were Good Year tires. I wonder how about those who had blowout within 7-8 years, what brand were they? I will definitely change the rear michelin xrv at 7 years.
