View Poll Results: Where have you had a roof water leak?
Front cap and roof attachment 12 70.59%
Rear Cap and roof attachment 1 5.88%
From seals above slides 3 17.65%
From windshield rubber 3 17.65%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Old 05-23-2013, 09:28 PM   #1
Iggy's Avatar
Where are roof water leaks on Georgetowns
This survey is to find out where the most roof water leaks originate from.
So far I had a water leak on the windshields upper top rubber seal, passenger’s side.
Old 05-23-2013, 10:43 PM   #2
Cornelius's Avatar
None of the above. My Georgetown leak was where the coax from the satellite dish enters the roof. Not Forest River's fault, and an easy fix.
Cornelius is offline   Reply With Quote
Old 05-24-2013, 07:30 AM   #3
bubbles's Avatar
I had an identical leak as IGGY. While driving through a hard rain there would appear a few rain drops running down on the inside of the windshield on the copilots side. My inspection of the windshield rubber gasket on the outside revealed a possible area of water ingress (appeared to not be fully seated). I applied some caulk to the suspect area and thus far no more water has entered. Saga continues.
Old 05-24-2013, 08:02 AM   #4
Herk7769's Avatar
Poll needs a "no leaks so far"
HAM CALLSIGN - KC3FFW
Old 05-24-2013, 08:16 AM   #5
Iggy's Avatar
Lou
Yes but it's to late to add. Anyway this is stickly Georgetowns. A no leak is not necessary as most have no leaks. I just want to see where most happen so I and others can do some proactive maintenance before the damage.
You counting the days for the 4th of July adventure?
Have fun.
Old 05-25-2013, 04:29 PM   #6
I had the same upper right corner windshield leak on my maiden voyage. I called Mike Burnes at Forest river and was told to stop by the factory which I did since we were going that way. The windshield was removed and resealed.Its been ok ever since. Stopping there was quite an experience.The water tank was filled with water,I was hooked to a 50 amp service and told to stay as long as I wanted.
johnnypal is offline   Reply With Quote
Old 05-25-2013, 06:23 PM   #7
Tim & Lisa Trempert
Mine was in the right front corner of the roof where they leave a channel for the water to run off the roof.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 05-26-2013, 05:53 PM   #8
No identifiable leaks so far, but when I was on the roof to seal the cracks in the Fiberglas roof, I noticed that all four corners were very poorly sealed by the factory. Given
The amount of water that flows over those areas I'm surprised that it wasn't leaking. I'd suggest everyone take a look at those areas to be sure they are waterproof.
2011 Georgetown 378 towing 2011 Chev HHR 2LT
ohiobill is offline   Reply With Quote
Old 05-26-2013, 06:48 PM   #9
Iggy's Avatar
We have to have more useres that have had their Georgetown for many years to jump in. I plan in the near future do some work on all 4 corners.
Not sure what I will use yet.
Elastimold tape 4" wide or 6" or non-levelling sealer.
Suggestions are always welcome here.
Old 05-28-2013, 02:09 PM   #10
Freds342's Avatar
My 2000 360SS leaked around the front running lights and the cap-to-roof seam.
I used a length of 6" Eterna-Bond across the roof, and replaced and resealed the lights.
No problems after that.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
