Old 09-20-2016, 05:33 PM   #1
Where did they hide my inverter
I have a 2014 Georgetown XL 377. Does anyone know where they put the inverter? I can find the switch, but it does not appear to do anything. Either the switch is bad or the inverter is bad (or maybe needs reset). If it is bad I need to replace it......I just cannot find where they hid it.
CarefreeCorses is offline   Reply With Quote
Old 09-20-2016, 05:40 PM   #2
On my 2015 377 it is in a compartment above the propane tank. There is a round screw off cap that you can look in and see it. If you need to work on it you will need to remove the black panel.
Georgetown XL 377TS
USAF-- CMSGT Retired.
georgew48 is offline   Reply With Quote
Old 09-20-2016, 06:11 PM   #3
Thanks, its right where you said it was, now I just need to figure out why there is no power to it
Old 09-20-2016, 09:32 PM   #4
Uwntgess123's Avatar
When mine didn't have power turned out that the gfi popped on the outlet it was plugged into.
Uwntgess123 is offline   Reply With Quote
Old 09-21-2016, 09:16 AM   #5
No power in, GFI does not work without input power.
Old 09-21-2016, 10:28 AM   #6
In the case of these inverters the GFI is not the input...it is the output. The remote button will glow green, meaning that the inverter is powered and running but the load will not receive any AC since the output goes through a GFI duplex outlet on the back. Reset the GFI and all is well.
If the remote switch doesn't glow green, the inverter is not running. Could be a fuse is blown or something on the DC side. If that is the case, put a meter on the DC input lugs on the back of the inverter to see if there is power. If there is...
If the remote switch is bad or unplugged you can power the inverter up with the switch on the front of the unit. There is also a display that will give you nominal DC voltage as well as instantaneous power consumption.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 09-21-2016, 11:49 AM   #7
chrisbailey13's Avatar
If the problem is no power to the inverter, Look near your batteries. there should be a breaker that looks similar to this
that connects to the 12v wire that goes back to the inverter. It may have tripped.
You will probably have two of them under there.
2014 Georgetown XL 352QS
2013-2017 Days Camped-170
chrisbailey13 is offline   Reply With Quote
Old 09-21-2016, 12:52 PM   #8
Havasu Bill's Avatar
As mentioned in earlier comments.
1. The gfci outlet on the inverter can trip. Mine did numerous times and I finally tore the inverter apart and changed out the gfci to a standard duplex receptacle. Everything works fine now and the 5er has gfci receptacles inside.
2. The input fuse FR installs is 80A and Xantrex recommends 250A for the 200W inverter. I changed that out to a 250A and all is good now.
Havasu Bill is offline   Reply With Quote
Old 09-21-2016, 01:11 PM   #9
GreenImp's Avatar
Send a message via MSN to GreenImp
This does not compute. A 200w inverter only needs about 20 amps of DC input (assuming it runs on 12v DC).
Also...
Did you increase the wire size too? If not you have created a potential fire hazard. Fuse sizes are dictated by the size of the wiring they are supposed to be protecting. I'm not so much posting this to tell you that you did it wrong (how far would that get me?), but more so that others coming along and reading this realize the risk.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 09-21-2016, 01:13 PM   #10
That's a typo, Xantrex makes a 2000 watt inverter, not a 200 watt unit. Normally FR uses a 2000 watt unit for the residential reefer.
2015 335DS
inverter
