Old 11-20-2015, 06:37 PM   #11
No, it was under the motorhome, outside, through an access hole.
hjcvn is offline   Reply With Quote
Old 11-20-2015, 08:37 PM   #12
When you look at your water heater panel from the outside of the unit. lay on your back look under the unit, you will see a white disk, about 4" in diameter. unscrew that disk and you will see the shut off and by pass valves about an arms length inside that disk. Now you will need a flashlight and don't empty the hot water bottle, or you'll be laying in a lot of water.
Dc8mdtmech is offline   Reply With Quote
Old 11-21-2015, 05:10 AM   #13
Thanks so much. This is exactly correct! Job done!
Old 11-21-2015, 06:03 AM   #14
glad you found it, mine was behind the mud flap in the wheel well, and even after opening it, you could barely reach it.....sometimes I wonder what these people are thinking when they design this stuff
Carmen is offline   Reply With Quote
Old 11-21-2015, 08:10 AM   #15
Wolverine 1945's Avatar
Under the MH !!!
Sounds like a really Pain in the A !!!
Wolverine 1945 is offline   Reply With Quote
Old 11-21-2015, 10:35 AM   #16
Now you have to open the water pump panel, slide the plastic door left, you'll see the clear hose with the metal cap, take the cap plug off. Just to the hose end of the pump is the hose suction valve. Open it. Stick the hose in the anti freeze bottle and then go in and turn on the pump. Once the pump is on , turn on every faucet, hot and cold one at a time until the pink anti freeze flows. Be sure someone is outside watching the bottle of anti freeze. Very easy job, takes two people. Oh yea the hose cap does not fit inside the anti freeze bottle. Different bottle or cut off the cap
heater, hot water, water, water heater
