Old 05-11-2012, 08:53 PM   #1
mbrwr's Avatar
Where is my fresh water drain??
We have a Georgetown 351DS and I need to drain and sanitize my fresh water tank but I have no idea where the drain is. I called Forest River and believe it or not the guy there didn't know either. any help will be very appreciated!!!
mbrwr is offline   Reply With Quote
Old 05-11-2012, 09:53 PM   #2
Herk7769's Avatar
Believe it or not Forest River is a big place.
They even make the Coachmen campers and RVs.
Someone with a Georgetown will be along shortly
HAM CALLSIGN - KC3FFW
Old 05-11-2012, 10:05 PM   #3
Look underneath the rv where the water tank is situated...
polkatronron is offline   Reply With Quote
Old 05-11-2012, 11:03 PM   #4
Frank4's Avatar
Found mine in the cabinet where the water pump and tank was located. It is a valve coming off the tank and going into the floor.
Frank4 is offline   Reply With Quote
Old 05-11-2012, 11:03 PM   #5
jsutherl's Avatar
Mine are in the propane compartment. There are two. The water tank drain and the low point plumbing drain. On mine they where both 1/4 white PEX pipes that stick down into the propane compartment from above and have caps on the end.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 05-12-2012, 10:42 PM   #6
ronhanson's Avatar
Each model is likely to be a little different. Mine is right under the tank behind the passenger side rear wheel.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 05-16-2012, 12:28 PM   #7
Iggy's Avatar
Mine is located with the pump and water tank access panel from exterior.
Name:	Motorhome Home 016.jpg
Iggy is online now   Reply With Quote
Old 05-17-2012, 04:18 PM   #8
mbrwr's Avatar
Whew! We got it. Behind right rear tire. Thanks everybody
